Author Topic: Radiator cap pressure?  (Read 2862 times)
September 27, 2009, 09:31:22 am
westcoaster
« on: September 27, 2009, 09:31:22 am »
What pressure radiator cap should a 1.6TD run?
Too low a pressure it can overheat, too high a pressure could cause headgasket problems.
13psi?
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #1September 27, 2009, 10:57:53 am
Re: Radiator cap pressure?
« Reply #1 on: September 27, 2009, 10:57:53 am »
it needs a VW specific cap. i think they run at some non-standard pressure. something rediculiously low.
Reply #2September 27, 2009, 01:43:27 pm
westcoaster
« Reply #2 on: September 27, 2009, 01:43:27 pm »
Hmmmm....
This could be a problem then.
I'm getting a radiator made for my samurai conversion and need to let them know what it is.
Reply #3September 27, 2009, 01:55:42 pm
« Reply #3 on: September 27, 2009, 01:55:42 pm »
Robert Bentley says the cap should release at:
1.20 to 1.35 bar (17 to 19 psi).
and the system test pressure (without the cap on) is 18 psi.
Reply #4September 27, 2009, 07:53:06 pm
« Reply #4 on: September 27, 2009, 07:53:06 pm »
ok, maybe its rediculiously high then. haha, i had it backwards.
Reply #5September 27, 2009, 10:18:59 pm
westcoaster
« Reply #5 on: September 27, 2009, 10:18:59 pm »
Ridiculously high is right....
17 to 19 psi? Gotta make sure I don't blow apart the heater core in the samurai
I think I might have to settle for a 16psi cap to sort of split the difference. Thoughts?
Reply #6September 28, 2009, 03:56:01 pm
Peter
  • 136
« Reply #6 on: September 28, 2009, 03:56:01 pm »
  generally speaking turbo models of any manufacture will have higher pressure caps with no change to the stock rad..just an example my subi N/A 16psi ..turbo model 18psi ..aftermarket cap from crucial racing 1.4 bar or 20.3 psi..no problems
