1.9td idle
Topic: 1.9td idle (Read 2085 times)
October 02, 2009, 12:41:42 pm
dokarex
1.9td idle
October 02, 2009, 12:41:42 pm »
Which way do you turn the idle screw to lower the idle?
clockwise or counter clockwise?
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
October 02, 2009, 01:07:37 pm
rallydiesel
Re: 1.9td idle
October 02, 2009, 01:07:37 pm »
I think you're talking about fuel screw. You want to turn the threaded rod on the back of the pump to allow the "throttle" arm to move farther clockwise to decrease idle.
1991 Jetta TD - sold
2001 Golf TDI - Son's
October 02, 2009, 04:17:32 pm
dokarex
Re: 1.9td idle
October 02, 2009, 04:17:32 pm »
so you back the idle screw out right to allow the throttle arm to come up
B6200 Kubota Diesel
16ft Sunray 85HP
October 02, 2009, 06:32:02 pm
rallydiesel
Re: 1.9td idle
October 02, 2009, 06:32:02 pm »
Yeah, you allow the throttle arm to stop further back.
1.9td idle
