» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
SELINOID PUMP MOD PROBLEM!
Could someone tell me what turbo this is please.
1.6 TD cam questions
Redonkulous (yet preliminary) MPG figures for a 1981 Caddy
T3 on AAZ, 2.5" or 3" exhaust?
K24 2.5" downpipe wanted
idle adjustment screw?? WHERE??
IP outlines - check valves?
Rough with A/C on
Fuel pump scew
Do 1.5 and 1.6 NA manifolds and bolts interchange?
1.9 AAZ upgrade for 92 Jetta TD
Using a gasser intake?
dynamic timing ..??
That Does It, I'm Building a GTD
AAZ 1.9TD Rover pin part number
MF 1.6 TD Injection Pump on AAZ 1.9 TD
1.6 into a type 3 squareback
Tbelt not tracking right
EGT QUESTION
This should to flow a little better...
1.9 TD/i Question?
tranny questions
boost gauge help
$0.81/L
Hydrogen Fuel Brown Gas Anyone? Increase MPG
intercooler piping questionn
BIG question?????????
water temp sensor location
Are all hydro 1.6 TD heads the same?
turning up boost on 1.9
Camshaft error? help
Mod 1.9TD pump with TDI Plunger?
D24 front flange
85 Golf Diesel -yay or nay-
Scangage 2
Hybrid injection pump
1993 AAZ won't fire. Help
Fan. Bosch part number.
Stripped threads in block- best option?
Help Please!!!!
115 bar injectors??
Bug-In, Ennis, Tx. Sunday June 1st
Will it fit?
Testing condition of 1.6td engine
anything conclusive on oil filter relocation kits?
IT SHOULD BE LAW TO OWN A DTI GAUGE
IP: hose to manifold?? help
Headgasket, rings or other?
Exploding mechanical headgaskets
