Author Topic: Rough with A/C on  (Read 4871 times)
June 02, 2008, 03:12:49 pm
Mopar44o
  • 60
Rough with A/C on
« on: June 02, 2008, 03:12:49 pm »
Hi guys, New to VW's and Diesel here.
Just got a 96 vw jetta gl diesel. Runs great except when ac is on.
It blows ice cold and when cruising at 2000+ rpms no problems
The problems are when the ac is on and I take it out of gear the rpms drop really low and it almost stalls out (stalled once). Or when trying to get rolling from a stop I gotta rev the *** out of it and it idles low and rough.
Other than when the ac is on though I have none of these problems. Anyone know what the cause is and how to fix it?
Thanks
V
Reply #1June 02, 2008, 03:24:55 pm
gigaz2
  • 626
Rough with A/C on
« Reply #1 on: June 02, 2008, 03:24:55 pm »
what engine do you have?
Reply #2June 02, 2008, 03:26:19 pm
Mopar44o
  • 60
Rough with A/C on
« Reply #2 on: June 02, 2008, 03:26:19 pm »
Its a turbo diesel So im guessing in 96 its the 1.9 no?
Reply #3June 02, 2008, 03:30:10 pm
gigaz2
  • 626
Rough with A/C on
« Reply #3 on: June 02, 2008, 03:30:10 pm »
it helps when we know what engine you have under the bonnet ;)
Reply #4June 02, 2008, 03:42:43 pm
Mopar44o
  • 60
Rough with A/C on
« Reply #4 on: June 02, 2008, 03:42:43 pm »
Well please correct me if I'm wrong but they only had one turbo diesel option in 1996 no? The 1.9L right? So that would pretty much narrow it down
And we call it a hood over here ;)
Reply #5June 02, 2008, 03:42:50 pm
Rough with A/C on
« Reply #5 on: June 02, 2008, 03:42:50 pm »
Quote from: "Mopar44o"
Unless you've had an engine swap you have the AAZ version of the engine... and it should have a fast-idle actuator that bumps up the idle when the A/C clutch comes on.
It's a black plastic device on the top of the injection pump with vacuum connections to a solenoid valve.... it has a cable that pulls on an IP lever.  Sounds like yours is defective/missing.
Reply #6June 02, 2008, 03:44:07 pm
Rough with A/C on
« Reply #6 on: June 02, 2008, 03:44:07 pm »
This is an international forum... you would do well to respect the fact that there are many different people here from many different countries... not all of whom call it a hood.  :wink:
This also means that what actual engine you have *is* a relevant question.... not only did VW ship many different engine configurations worldwide but many folks have done engine swaps.
Reply #7June 02, 2008, 03:52:23 pm
Mopar44o
  • 60
Rough with A/C on
« Reply #7 on: June 02, 2008, 03:52:23 pm »
I was just joking with the hood comment no harm meant. Sorry buddy if you were offended it wasn't the intention.
Im pretty sure I know what you're talking about with the actuator is their a way to test it or adjust it?
Reply #8June 02, 2008, 04:11:31 pm
gigaz2
  • 626
Rough with A/C on
« Reply #8 on: June 02, 2008, 04:11:31 pm »
no prob on my behalf ;)
you can apply vacuum directly to the canister, it should move and make the idle go higher in order to cope with the AC load.
Reply #9June 02, 2008, 05:05:10 pm
Rough with A/C on
« Reply #9 on: June 02, 2008, 05:05:10 pm »
in america they call it a mushroom and in the europe they call it an elephant trunk
Reply #10June 02, 2008, 06:14:16 pm
Mopar44o
  • 60
Rough with A/C on
« Reply #10 on: June 02, 2008, 06:14:16 pm »
It  looks like there are several hoses coming off the acutuator which one is the vacuum line that is responsible for pulling the cable?
Reply #11June 02, 2008, 07:11:14 pm
Rough with A/C on
« Reply #11 on: June 02, 2008, 07:11:14 pm »
no harm meant.
Me neither... I myself get "toque" and "hat" mixed up all the time. And then there's "haggis" and  "food poisoning"  ;-)
All of the AAZ fast-idle actuators I've seen only have one hose connection:
On mine that one hose leads to a solenoid valve mounted on the passenger-side shock tower.  From the solenoid valve another hose goes to the a tee fitting on the vacuum pump.
Sound familiar, or perhaps yours is a different configuration ??
Reply #12June 02, 2008, 07:46:30 pm
Mopar44o
  • 60
Rough with A/C on
« Reply #12 on: June 02, 2008, 07:46:30 pm »
Heres photos of mine i snapped now.
Looks a little differnt from yours[/img]
Reply #13June 02, 2008, 07:58:19 pm
Rough with A/C on
« Reply #13 on: June 02, 2008, 07:58:19 pm »
Reply #14June 02, 2008, 08:00:00 pm
Mopar44o
  • 60
Rough with A/C on
« Reply #14 on: June 02, 2008, 08:00:00 pm »
That thingy is my improvised fuel line that replaced the one that cracked twice :D the line to the #2 injector crack twice on me. Thats a gm 6.3 L diesel line straightend out and bent to "fit"
