Author Topic: water temp sensor location  (Read 2113 times)
June 03, 2008, 03:26:10 pm
turbosuzi
« on: June 03, 2008, 03:26:10 pm »
what is the best location for an after market water temp sender on the 1.6td?
I have an aftermarket gage cluster for the samurai but I was wondering if you guys had a good location for the sender because the new one wont fit in the old hole.
Reply #1June 03, 2008, 06:45:24 pm
« Reply #1 on: June 03, 2008, 06:45:24 pm »
I'd put it by either of the head coolant flanges, as close as possible to the head.
Reply #2June 03, 2008, 07:02:52 pm
turbosuzi
« Reply #2 on: June 03, 2008, 07:02:52 pm »
does coolant flow out of both of the flanges?
Reply #3June 03, 2008, 07:41:49 pm
« Reply #3 on: June 03, 2008, 07:41:49 pm »
Yup.
There were various head coolant flanges over the years.... and several (specifically the ones for cars equipped with AC) have an extra port for a temp sensor.... cheap to buy 'cause they are plastic.
The early ones expect a M10x1 sensor and the later ones use a cartridge sender but you can get a brass adapter from www.toywagen.com and drill/tap to suit... I did the latter on my MK3.
