Author Topic: MF 1.6 TD Injection Pump on AAZ 1.9 TD  (Read 3040 times)
June 06, 2008, 05:47:19 am
Joe B
  • 5
« on: June 06, 2008, 05:47:19 am »
I am about to install a MF 1.6 TD series injection pump on a AAZ 1.9 TD. Apart from using the 1.9 injector pipes and the 1.6 bracket to align the pump pulley, is there anything else I should be aware of?
What would the ideal injectors be GTD perhaps (due to the difference in pressure between the 1.9 and 1.6 injectors) ?
The reason behind is that from what I have picked up in the forum I think this pump lends itself more to tunning. I will also change the turbo to a 1.6 T3 for higher boost.
Anyone out there gone thru this exercise before?
By the way, are the 1.6 and 1.9 head ports the same, so I can also use the 1.6 manifolds?
Many Thanks
Reply #1June 06, 2008, 07:22:52 am
Re: MF 1.6 TD Injection Pump on AAZ 1.9 TD
« Reply #1 on: June 06, 2008, 07:22:52 am »
Quote from: "Joe B"
If you change injectors, you can set the pressure at whatever you want, especially since they should be tested/adjusted with new nozzles anyways.
Quote from: "Joe B"
I never remember reading that on here. There isn't much different between the pumps as far as I know.
Quote from: "Joe B"
Nope. 1.9 has D ports, 1.6 has  round.
Reply #2June 06, 2008, 11:33:57 am
rallydiesel
  • 1880
« Reply #2 on: June 06, 2008, 11:33:57 am »
I don't see any reason why you couldn't. I think the camplates are different so you maybe want to find a 1.9TD camplate so you get more lift.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
