Author Topic: 115 bar injectors??  (Read 2254 times)
May 31, 2008, 09:31:09 am
Greasecar
  • 126
    • http://www.greasecar.com
115 bar injectors??
« on: May 31, 2008, 09:31:09 am »
My friend just refreshed his engine with a head job and a set of injectors from VW Diesel Parts.  He called me up last night because he had been screwing with his timing for two hours and could not get the car running right and was looking for suggestions.  He had the timing set to 1mm and everything else by the book but the car would just run like crap and stall.
  From experience I know that if you accidently put 155 bar injectors on an NA with stock pump tuning it will idle like crap so I suggested he check his "new injectors" to make sure they were 130 bar. They are stamped 115 bar!  I have never even heard of that spec before.  Anyone else? I can't even imagine what they would be for. Needless to say he is planning on swapping them out before wasting any more time.
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #1May 31, 2008, 10:01:23 am
Re: 115 bar injectors??
« Reply #1 on: May 31, 2008, 10:01:23 am »
Quote from: "Greasecar"
how much were they? might be easier just to get them calibrated at a diesel shop if the nozzle is new...
Reply #2May 31, 2008, 10:56:37 am
Greasecar
  • 126
115 bar injectors??
« Reply #2 on: May 31, 2008, 10:56:37 am »
VW Diesel Parts sent him the wrong ones so I think he is planning on returning them for the right ones.
www.greasecar.com
Reply #3June 01, 2008, 05:21:14 am
mdonau
  • 53
115 bar injectors??
« Reply #3 on: June 01, 2008, 05:21:14 am »
115Bar is the spec for Mercedes..
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
