» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
push button eco?
CE1 rev counter in to CE2 clocks
oil squirters
1.6/1.6 TD & 1.9 1Y AND 1.9 TD AAZ MOTORS WITH & WITHOUT TRANSMISSIONS
need help identifying an IP
My MKI TD Project
1Y INTAKE on 1.9 TD AAZ
Mechanical head to hydraulic block.
Newbie 1.6 TD looking for 135 hp or better
Questions about gauge values
urgently need some help, belt squeal and glow plug light flicker
Exhaust system fell apart
Electric lift pump pressure
quick question about clutches
Accusump anyone ???
MKIII Rad fan schematics
Cooling System Fill/Bleed
Help with aaz IP problem
MKIII golf fusebox part number.
On cylinder sooty...
Vaccum pump
Temporaily running a TD pump on my NA?? is it allowed?
torque for turbo to manifold bolts?
A good combo for 200ish HP?
crunch going from 1st to 2nd
VW TD HYBRID 1.6 HEAD & 1.9 bLOCK??
200 dollar diesel pickup
AAZ Head Question
Timing tools for 1.9 aaz
1.6L engine rebuild...
Timing again, confused!
starter ground
1.6 Intake on 1.9 head? What have others done to make it work?
THIS IS THE POINT IN THE PROCESS WHEN I ADMIT I HAVE NO IDEA WHAT I AM DOING
Who has done a k24/k26 and are completely thrilled with the results?
idle adj. screw not working?adjust vnt linkage out of car?
What type of IC to use on 97 MK3
Thermostats compatibility
Can I get some details on this IP
tube header
NOOB Introduction
Injection lines. Sources?
Hi Guys..Turbo Advice needed
might sound stupid but......
1.9 TD oil light
Older Cabriolet
door mirror help needed
output flanges??? 90mm or 100?
IDI or TDI for a 72 Camper conversion?
Hesitation while taking off
