Author Topic: Injection lines. Sources?  (Read 2069 times)
August 15, 2009, 12:44:16 pm
trev
  • 67
« on: August 15, 2009, 12:44:16 pm »
I had the end crack on the #2 cylinder at the injector.
In my "stuff" I had 3/4 of a set of lines. Not that one, though. So one of the lines got butchered into fitting, there in the parking lot, and I'm mobile again. For now.
 Any sources for built up lines? I have a bud with access to a flaring tool, but the line is a bit of coin. Add to that the standard grade PITA to bend ...
 Are the lines available from other than dealer sources? NAPA? Part number?
 1990 1.6TD Jetta, FWIW.
 Or is it a wrecking yard adventure. Again.
 Cheers
  Trev
Reply #1August 15, 2009, 12:52:25 pm
rabbid79
  • 684
Re: Injection lines. Sources?
« Reply #1 on: August 15, 2009, 12:52:25 pm »
eBay store "MK1 Autohaus" sells whole sets for $60.  He also sells individual lines.  Dealer cost for a set is around $225.
'15 WRX
Reply #2August 15, 2009, 01:04:14 pm
« Reply #2 on: August 15, 2009, 01:04:14 pm »
i got some sets of lines... i would part with the one you need for cheap.
Reply #3August 17, 2009, 06:54:16 am
trev
  • 67
« Reply #3 on: August 17, 2009, 06:54:16 am »
Looks like I found a useable line, locally.
 I have replaced this line once about six months back. Either I got a dud line (it was used) or I didn't have it installed as free from misalignment as I thought I had.
 Really, I was careful, and did install the straps as per...
 If this one goes, I will look at a new set from the source on Ebay, I suspect.
 435000 kms and counting, and somewhere around 45 mpg. Not bad for a car that was essentially a freebie!
 Thanks for the info, both of you!
 Cheers
 Trev
Reply #4August 17, 2009, 12:33:38 pm
« Reply #4 on: August 17, 2009, 12:33:38 pm »
be sure to have the rubber vibration isolator mounts on your lines. there should be 3.
Reply #5August 18, 2009, 10:41:04 am
trev
  • 67
« Reply #5 on: August 18, 2009, 10:41:04 am »
Hmmmm.
 Had two for sure, one with 4 lines, the other with two lines.
 I'll check and see if there is marks from another two line clamp around.... I have a couple in my bench, IIRC.
 Thanks for that!
 Cheers
  Trev
