Author Topic: tube header  (Read 3122 times)
August 12, 2009, 11:48:12 am
smoken u
  • 231
tube header
« on: August 12, 2009, 11:48:12 am »
just a quick question anyone on here know where i can get or if someone on here fabricates tube headersfor the 1.6 TD???
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #1August 12, 2009, 12:40:36 pm
Re: tube header
« Reply #1 on: August 12, 2009, 12:40:36 pm »
basically any older 8v vw exhaust manifold fits, not just specific 1.6td parts. so if you can find yourself a turbo header off of a older GTI or ABA engine, it will bolt right up.
Reply #2August 12, 2009, 01:14:59 pm
smoken u
  • 231
Re: tube header
« Reply #2 on: August 12, 2009, 01:14:59 pm »
lol i know i can but i need somthing externallly wastegated, and one from a an audi with the wastegate facing upwards will not work as I am also using an intake from a 1.8 gasser.
Reply #3August 12, 2009, 07:55:48 pm
53 willys
Re: tube header
« Reply #3 on: August 12, 2009, 07:55:48 pm »
here is one I have been home building.....I am running mine with a 40mm External gate...But I wanted mine to point up for easy turbo access
I still gotta make two more notches for the two center runners..but it's getting close..(moving to a new house really slows progress ;))
Reply #4August 12, 2009, 10:47:14 pm
  • 3468
    • McScrubbins Body Wash
Re: tube header
« Reply #4 on: August 12, 2009, 10:47:14 pm »
Drool DROOL DROOL!!!Drrroooooollll!
you need a bigger intake manifold Willy!
Reply #5August 13, 2009, 03:24:51 am
smoken u
  • 231
Re: tube header
« Reply #5 on: August 13, 2009, 03:24:51 am »
what steel did you use for the exhaust flange looks to be at least 1/4 inch lol, yeah that looks awesome, gonna flow a helluva lot better than stock :)
Reply #6August 13, 2009, 07:39:36 am
53 willys
Re: tube header
« Reply #6 on: August 13, 2009, 07:39:36 am »
thanks Eddy...I got a new intake in the works..
the flange on it is 1/2"
« Last Edit: August 13, 2009, 07:49:19 am by 53 willys »
Reply #7August 16, 2009, 04:20:27 pm
smoken u
  • 231
Re: tube header
« Reply #7 on: August 16, 2009, 04:20:27 pm »
now if i was going to fab up my own header, should i use the 1/2 steel plate for the flange or 1/4 inch plate??? I know the 1/2" will definantly hold up to alot of abuse, but 1/4" is fairly beefy as well.
Reply #8August 16, 2009, 08:00:41 pm
53 willys
Re: tube header
« Reply #8 on: August 16, 2009, 08:00:41 pm »
for a turbo manifold I would go 1/2" myself...if your gonna build it you might as well build it right.
Reply #9August 17, 2009, 12:43:25 pm
53 willys
Re: tube header
« Reply #9 on: August 17, 2009, 12:43:25 pm »
I don't think 1/4" is thick enough for exhaust flanges near the head/turbo.  I'd go with at least 3/8".
Andrew
yeah for something that will heat cycle over and over at high temps I would want something thick!
Reply #10August 17, 2009, 01:09:43 pm
smoken u
  • 231
Re: tube header
« Reply #10 on: August 17, 2009, 01:09:43 pm »
lol yeah 1/2" is what i thought lol
Reply #11August 18, 2009, 01:43:54 pm
macka
  • 957
Re: tube header
« Reply #11 on: August 18, 2009, 01:43:54 pm »
1/2" or 5/8" for the flange, port match for size to the turbo, then open up the exhaust to at least 2.75".
Are you TIGging that or going with a MIG or ARC?
Quote from: Vincent Walden
