Author Topic: Help with aaz IP problem  (Read 2404 times)
August 17, 2009, 07:39:45 am
Henchman
  • 183
« on: August 17, 2009, 07:39:45 am »
93 Passat, drove fine yesterday, would not start this morning.  No fuel being drawn into IP.  Solenoid clicking, so I assume it works.  When I pulled and drained filter I found water, small amounts of veg oil/glycerin (hard to tell) and grime.  I run washed bio about 50% of the time.  I assume I have some contaminate in the injection pump that has now solidified.  I plan on changing the filter, topping up with clean diesel, and first try warming up the IP to operating temps and seeing if that frees up the blockage.  Failing that I think I would pull the solenoid and make sure it is actually working fine (I can hear it clicking now), but I assume that it must be some sort of blockage as it worked without issues for 100+miles and nothing this morning.
Any thoughts?
Thanks,
Ian
Reply #1August 21, 2009, 09:32:29 am
Henchman
  • 183
Re: Help with aaz IP problem
« Reply #1 on: August 21, 2009, 09:32:29 am »
Follow-up.
Turned out to be the fuel shut-off solenoid.  Replaced it with one from a parts car and runs like a champ again!  Thank for all who helped!  ;)
Ian
Reply #2August 21, 2009, 07:37:08 pm
macka
  • 957
« Reply #2 on: August 21, 2009, 07:37:08 pm »
don't feel bad, I ran new fuel lines and replaced my glowplugs to find out it was the fsos. I did the vince walden mod to the plug wires while I was at it. On the up side, I taught my son (he's 4) how to tighten bolts, and he started the bolts on the glowplugs for me.
Quote from: Vincent Walden
Reply #3August 22, 2009, 09:28:52 pm
Rabbit TD
  • 840
« Reply #3 on: August 22, 2009, 09:28:52 pm »
That's amazing for a little kid t be able to do that, he's definately gonna be either a good mechanic or a surgeon with the talent he's developing now ;)
Reply #4August 23, 2009, 08:43:58 am
« Reply #4 on: August 23, 2009, 08:43:58 am »
that reminds me of me. he will be rebuilding engines by the time hes 10.
Reply #5August 23, 2009, 07:20:17 pm
Rabbit TD
  • 840
« Reply #5 on: August 23, 2009, 07:20:17 pm »
And designing them by 12 ;)
Reply #6August 23, 2009, 08:01:39 pm
macka
  • 957
« Reply #6 on: August 23, 2009, 08:01:39 pm »
I hope so, I wouldn't mind retiring early. ;D
