Author Topic: torque for turbo to manifold bolts?  (Read 1996 times)
August 22, 2009, 01:25:26 pm
skifree
  • 32
« on: August 22, 2009, 01:25:26 pm »
Does anyone know what the torque is for the turbo to manifold bolts?
Reply #1August 22, 2009, 01:53:28 pm
jack's lack
  • 275
Re: torque for turbo to manifold bolts?
« Reply #1 on: August 22, 2009, 01:53:28 pm »
On the AAZ Bentley says 45Nm (33ft-lb) and recommends the use of anti-seize compound
On the 1.6 Bentley says 40Nm (30 ft-lb) in stages
do you not own a Bentley manual? You should it will be the best $40 you will ever spend on your car
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #2August 22, 2009, 07:31:29 pm
Rabbit TD
  • 840
« Reply #2 on: August 22, 2009, 07:31:29 pm »
Are they still just $40, I thouht they'd be twiice that by now but still worth every penny.  With a Bentley and this place you can acomplish anything  on these cars.  Without them you might as well just junk the damn things when they quit :D
