Author Topic: idle adj. screw not working?adjust vnt linkage out of car?  (Read 7390 times)
August 18, 2009, 12:59:47 pm
carrizog60
  • 978
« on: August 18, 2009, 12:59:47 pm »
tried to give a little more fuel to my passat but the idle screw isn't working...
the pump was stock,never touched but the idle wont go down...
same thing happened to my fathers 1.9d golf...
whats going on?
also is there a way to adjust the linkage on a vnt turbo without putting it to car?
was thinking on a air compressor blowing air and adjust it that way...
on a vnt20 in a 1.9td what is the best way to setup the vanes?motion vs boost?
thanks
Portugal
Reply #1August 18, 2009, 01:07:44 pm
Re: idle adj. screw not working?adjust vnt linkage out of car?
« Reply #1 on: August 18, 2009, 01:07:44 pm »
turn the max fuel screw down, if you turn it up too much, the max fuel screw becomes your idle adjustment also.
and for the vanes on the VNT, you want the vanes closed at idle, and as soon as the turbo starts boosting, you want the vanes to start opening. they should be fully open by about 10 psi. and you cant really adjust a turbo with compressed air, there wont be enough air moving through the turbo to spool it, just enough to make it spin slowly.
Reply #2August 19, 2009, 12:27:16 am
carrizog60
  • 978
« Reply #2 on: August 19, 2009, 12:27:16 am »
regarding the pump the settings were stock...
and the idle screw was not working...
right now the fuel screw is stock because i cant get the idle down....same thing happened on 1.9d pump...
the compressed air was to be blown on the WG to move the vanes, not through the turbo
Portugal
Reply #3August 19, 2009, 09:33:46 am
« Reply #3 on: August 19, 2009, 09:33:46 am »
a VNT doesnt have a wastegate. thats why its a VNT, to get rid of a wastegate. that canister is vacuum operated dude.
and what do you mean it wont idle down, like it never idles?
or you give it gas and it hangs at a higher rpm instead of returning to idle.
your discriptions are pretty vauge, tell me more about your problems and maybe i can help you.
« Last Edit: August 19, 2009, 09:35:51 am by Rabbit on Roids »
Reply #4August 19, 2009, 09:53:26 am
« Reply #4 on: August 19, 2009, 09:53:26 am »
What screw are you turning on the pump? A picture would be key
Reply #5August 19, 2009, 11:29:09 am
carrizog60
  • 978
« Reply #5 on: August 19, 2009, 11:29:09 am »
the idle screw.the one that sets the stop for the accelerator lever.
it wont affect idle at all and the setting are stock.
i modded my gtd pump and i could give it a lot of fuel and back out the idle on that screw,on these pumps it wont do squat...
regarding the turbo...
the canister is vacuum operated yes,but i will convert it to work with boost like everybody does.
said that is it possible to give it air by a air compressor and set the vanes opening vs boost?
and how would i limit the boost?
on my gtd with k24 i shut closed the wg and controlled the max boost with fuel but on vnt i think the boost levels will be too high...
« Last Edit: August 19, 2009, 11:31:25 am by carrizog60 »
Portugal
Reply #6August 19, 2009, 03:30:35 pm
« Reply #6 on: August 19, 2009, 03:30:35 pm »
That's because that isn't the idle screw. The idle screw is the rod that comes up from the cold start advance. That rotates and adjusts the idle. If you have AC with the vacuum pod then I think it is the screw with the 10mm lock nut closest to the injection lines, but I'm not sure
Reply #7August 19, 2009, 11:01:41 pm
« Reply #7 on: August 19, 2009, 11:01:41 pm »
its the one thats between the lda and injection lines.
the one on the fromt of the pump can be removed.
Reply #8August 20, 2009, 12:25:52 am
carrizog60
  • 978
« Reply #8 on: August 20, 2009, 12:25:52 am »
i adjusted the idle on my 1.6 on that screw(the stop for the lever) as on many other pump i have tweeked...
i dont have a.c.
Portugal
Reply #9August 20, 2009, 12:26:41 am
carrizog60
  • 978
« Reply #9 on: August 20, 2009, 12:26:41 am »
i backed that one and didnt do anything... ???
number 6
« Last Edit: August 20, 2009, 12:29:24 am by carrizog60 »
Portugal
Reply #10August 20, 2009, 03:02:50 am
nokivasara
  • 115
« Reply #10 on: August 20, 2009, 03:02:50 am »
Number 8 is the correct screw.
The 1.6 and 1.9 pumps are different pumps.
Caddy 1.6N/A pushing 400 000km and going strong!
Reply #11August 20, 2009, 04:54:12 am
« Reply #11 on: August 20, 2009, 04:54:12 am »
It actually should be #7, unless that adjustment is maxed out, then you would use # 8
Reply #12August 20, 2009, 05:09:58 am
carrizog60
  • 978
« Reply #12 on: August 20, 2009, 05:09:58 am »
are there so much difference in 1.6 and 1.9 pumps? ???
if i play with screw nš8 wont the cold start advance be deactivated?
Portugal
Reply #13August 20, 2009, 08:44:56 am
nokivasara
  • 115
« Reply #13 on: August 20, 2009, 08:44:56 am »
Ooops, of course it's #7, then #8 and the other right next to it if you need to lower it more.
The cold start lever only affects idle speed, not timing so it's safe to back them out. I had to back out #8 completely on my tweaked Passat.
Reply #14August 20, 2009, 10:37:48 am
« Reply #14 on: August 20, 2009, 10:37:48 am »
that udle system on the AAZ pump looks like its pretty much the same as the pump on my 2.0, except my pump has another delivery valve on the back.
