» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
replacing wastegate
New camshaft won't rotate. What did I do wrong?
Smoke from oil cap
clutch cable not grabbing
ecodiesel questions
1.5 head studs?
Questions about head gasket, blow by, valve seals
AAZ nozzles/injectors upgrade?
Replace leaking fuel lines on MK2 with viton?
EGT Temps (Was NA now Turboed) HELP!!
KKK K24 Boost Controller?
Stock boost in my AAZ
De-fueling for economy?
Swain-tech ceramic coatings
ARP studs; to retorque or not to retorque?
t3/t4 turbo /w no wastegate?
Injector nozzles for an AAZ?
'89 1.6 TD power upgrades ???
EGT probe/gauge help please.
Oil for diesel additive
Calibrating the injector pump
k14 parts needed
Fuel Economy mods
Fuel Injector pump leak
AAZ - weird pump, coupla questions.
HEAT SHIELDS
pump top cover interchange
Why MPG better on TDI then IDI?
How to remove oil pan on Turbo?
is there gear oil behind this tin cover on trans?
Tuning a 1.6 N/A engine
Block heater alternative
GT28rs
hatch and estate 5th gear?
Exhaust piping seal
too fast now 8-))
Can I force more air into a NA?
MK2 GTD 1.9 VNT History of a SWAP(s)
starting issues after installing a na pump on eco td
Wastegate gradually open or just full open/closed?
aaz golf estate coilovers
what tis needed to have a 6000 redline?
tranny ratios for trans #chd29092
Where can I order a DGK 121 / 1 467 010 467 Seal Kit Online?
pump changed, I need a hand
Cold Temp Coolant Heater
Are there different kinds of glow plug relays??
Inserts Falling Out
4-motion / AWD Diesel Swap In?
turning fueling up?
