Author Topic: is there gear oil behind this tin cover on trans?  (Read 3358 times)
November 05, 2007, 07:22:11 pm
trent77
  • 217
« on: November 05, 2007, 07:22:11 pm »
My trans number is chd29092  where the clutch release lever is on the end of the transmission, there is a round tin cover that has a vw symbol on it. mine is a little banged up, is there oil behind the cover, or is it sealed before it gets there? I appreciate all your help. the trans is on a canadian aaz 1.9
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1November 05, 2007, 07:55:33 pm
trent77
  • 217
« Reply #1 on: November 05, 2007, 07:55:33 pm »
also, does anyone know the ratios for this trans? My bentley manual doesn't offer the info for this trans code. Or is it possible that I have the wrong numbers off the trans?
77 westfalia
06 GMC Duramax
Reply #2November 05, 2007, 07:58:59 pm
« Reply #2 on: November 05, 2007, 07:58:59 pm »
Yup there's oil.... the cover is cheap to replace but draining the tranny is recommended.
This guy has a fantastic site on 020 transmissions.... here's what it looks like with that cover off:
http://www.brokevw.com/releasearm.html
(second picture down)
You pry the old cover off with a screwdriver, and tap the new one on with a hammer.... easy as that !
Reply #3November 05, 2007, 08:03:19 pm
flapjack
  • 283
« Reply #3 on: November 05, 2007, 08:03:19 pm »
the cover over the throw out bearing?
i've had that off , no oil came out :)  but i had the car jacked up no that side . ..
signature
Reply #4November 06, 2007, 06:08:39 am
trent77
  • 217
« Reply #4 on: November 06, 2007, 06:08:39 am »
well now I have a yes and a no. anyone to break the tie?
77 westfalia
06 GMC Duramax
Reply #5November 06, 2007, 06:34:11 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #5 on: November 06, 2007, 06:34:11 am »
I just pulled mine off.  Car jacked up high enough on left front for the tire to clear the ground, no oil running out of the cover.  There was a bit of oil in there, but not leaking out.
Calvin
91 VW Golf 1.6NA 5spd
Reply #6November 06, 2007, 05:51:15 pm
mk2diesel
  • 60
« Reply #6 on: November 06, 2007, 05:51:15 pm »
there should be oil drooling out IF your tranny was properly filled ...
most shops just fill through the side plug and let it go at that ... specs call for another 1/2 L  on top of that ... ( thru the speedo cable fitting)
BUT the tranny WILL WORK FINE, if  low on oil .....
Reply #7November 06, 2007, 06:23:00 pm
Black Smokin' Diesel
  • 656
« Reply #7 on: November 06, 2007, 06:23:00 pm »
Quote from: "mk2diesel"
Depends on which tranny. As per Bentley: "Beginning with transaxle no. 08097 (built 9/8/87) the oil filler hole has been relocated 7 mm higher. Proper oil fill level is when oil reaches the edge of the filler hole. It is no longer necessary to remove the speedometer drive cable and add additional oil."
Reply #8November 06, 2007, 08:36:19 pm
« Reply #8 on: November 06, 2007, 08:36:19 pm »
There had better be oil behind that cover on level ground, since that's how the throwout bearing is lubricated, and the clutch arm, and.... !!!
Reply #9November 06, 2007, 11:19:53 pm
« Reply #9 on: November 06, 2007, 11:19:53 pm »
Quote from: "Vincent Waldon"
thank god the older vw diesel tranny's aren't too expensive  :lol:  i have 2 n/a's and 2 td's.
Reply #10November 08, 2007, 08:30:34 pm
trent77
  • 217
« Reply #10 on: November 08, 2007, 08:30:34 pm »
I guess I just thought that throw out bearings thru the ages have just lived inside the bell housings of multiple automobiles and had no outside lubrication. I just didn't figure VW would put a slight press fit tin cover where it was under possible oil pressure. thanks for all the info.
77 westfalia
06 GMC Duramax
Reply #11November 09, 2007, 12:52:32 pm
« Reply #11 on: November 09, 2007, 12:52:32 pm »
Don't get me wrong... it's not brimming with oil (there's only 2l in the whole tranny) but were you to pull that cap with the car level a thin stream will come out.
My guess is that there's a mist of oil being thrown around in the tranny airspace that lubes everything.. including the throwout bearing, clutch lever, etc.
Reply #12November 09, 2007, 03:28:32 pm
  • 656
« Reply #12 on: November 09, 2007, 03:28:32 pm »
Yes the gears throw a lot of oil around, that's how it lubricates the whole tranny.
