Author Topic: turning fueling up?  (Read 4300 times)
November 04, 2007, 01:23:25 am
rov716y
  • 96
turning fueling up?
« on: November 04, 2007, 01:23:25 am »
the car runs bad at low revs and idle as you know.  i have adjusted the timing all the way one way and back again and makes no difference so i set it back to how it was.
seems to run better with cold start out.  how do i turn the fuel up!! basically which screw is it?
is there anything else i can do with the engine to get more power?
Reply #1November 04, 2007, 08:39:49 am
g-spec
  • 289
turning fueling up?
« Reply #1 on: November 04, 2007, 08:39:49 am »
From what it sounds like you werent setting the timming properly....in order to set the timming on a diesel you need special tools. and the injection pump should be set at 0.85-1.05mm advance. I would set up the timming properly first and then start trying to make the car faster.
If the car runs better with the cold start pulled out it sounds to me like your timming is retarded....
good luck
Reply #2November 05, 2007, 09:15:06 am
rov716y
  • 96
turning fueling up?
« Reply #2 on: November 05, 2007, 09:15:06 am »
turned fuel up and the knocking seams to have disappeared and all good a lot of healthy black smoke too
Reply #3November 05, 2007, 10:34:52 am
turning fueling up?
« Reply #3 on: November 05, 2007, 10:34:52 am »
Quote from: "rov716y"
Black smoke is unburnt fuel which is high EGTs. It sounds like your pump is off a tooth. Get it timed using the proper tools.
Reply #4November 05, 2007, 12:48:47 pm
rov716y
  • 96
turning fueling up?
« Reply #4 on: November 05, 2007, 12:48:47 pm »
the pump is timed up correctly and even taking its slightly advanced or retarded it makes no difference i am on the understanding its not the right pump for the engine
Reply #5November 05, 2007, 01:31:49 pm
g-spec
  • 289
turning fueling up?
« Reply #5 on: November 05, 2007, 01:31:49 pm »
what is it set at??? Cause im thinking that is your main problem. I had the similar issues
Reply #6November 05, 2007, 01:42:16 pm
rallydiesel
  • 1880
turning fueling up?
« Reply #6 on: November 05, 2007, 01:42:16 pm »
Blown engine in 3..2..1 Just kidding, sort of. Black smoke can be bad for more than a few seconds.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7November 05, 2007, 04:54:43 pm
turning fueling up?
« Reply #7 on: November 05, 2007, 04:54:43 pm »
Quote from: "rallydiesel"
i think the longest i've smoked bad was for 5-6 seconds (couldn't see the car behind me, except a middle finger sticking out  :lol:)
the turbo motors can surely take a beating, but they do have a breaking point.
Reply #8November 05, 2007, 05:00:01 pm
g-spec
  • 289
turning fueling up?
« Reply #8 on: November 05, 2007, 05:00:01 pm »
Mine smokes like mad....but i do have a pre turbo mounted egt guage and i never have seen it exceed 600 degrees C (thats about 1100F for you americans). and i have to really try for it to hit that high....usually sits around 400 with spirited driving.
I havent figured out why it smokes....timming is set at 1.00mm head was redone along with rebuilt and tested injectors. I also have other problems that are leaning me towards a worn pump!!
Reply #9November 06, 2007, 10:18:20 am
rov716y
  • 96
turning fueling up?
« Reply #9 on: November 06, 2007, 10:18:20 am »
NON TURBO 1.6 NA!!
 i am going to get the timing double and treble checked at a garage me thinks just to make sure as all timed up right with how i followed the haynes manual all marks line up etc so cant be out. can it!!
Reply #10November 06, 2007, 10:34:05 am
g-spec
  • 289
turning fueling up?
« Reply #10 on: November 06, 2007, 10:34:05 am »
Did you do it yourself?? if so did you use a dial guage????
If you didnt use a dial guage to time the pump then it could be out.....
timming a diesel is not as simple as doing a gas car where you line up the marks and your done.....the cam does not have a keyway on it....so you have to have a special tool to lock it at tdc....and you also have to lock the pump at tdc....and then you use a guage to time the pump correctly!!!
Reply #11November 06, 2007, 12:02:58 pm
rov716y
  • 96
turning fueling up?
« Reply #11 on: November 06, 2007, 12:02:58 pm »
i did do it myself yes.
lined up flywheel mark
flat bar in end of cam to lock off
socket through pump pully to hold in place
put belt on tightened up turned over by have three or four times
all still lined up struck her up and she ran
then put engine in car and not much else changed since
forgot to mention this.  the water system seams to get pressurized so i have to leave the rad cap slightly loose to let of pressure.  it seams to have the same white smoke that comes out of the rocker breather in it
Reply #12November 06, 2007, 12:11:22 pm
g-spec
  • 289
turning fueling up?
« Reply #12 on: November 06, 2007, 12:11:22 pm »
You should use a dial guage to time it correctly....it is very hard to adjust the pump by just trying to advance and retard it.
It could be a headgasket problem if you have pressure in the coolant...and white smoke!!!!!
Have you replaced the headgasket??? do you have coolant mixing with oil???? is there a lot of pressure comming out of the breather????
Reply #13November 06, 2007, 12:20:39 pm
rov716y
  • 96
turning fueling up?
« Reply #13 on: November 06, 2007, 12:20:39 pm »
i will see if i get get a gauge then!
i fear the head gasket too i never touched it i have no oil loss no water loss not water in oil or other way round and yes it does breath heavy.
i plan to change engine for a td in the not so distant future but it would be nice to have this engine last till then
Reply #14November 06, 2007, 01:26:13 pm
turning fueling up?
« Reply #14 on: November 06, 2007, 01:26:13 pm »
Quote from: "g-spec"
what boost are you running?  could be signs of bad compression.  no new rings?
