» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
connecting rod bolts
How to easily identify a 36mm Oil Pump
poor mpg on biodiesel
Is this cam done for?
high volume oil pump ......
1.6 TD head...
1.6NA no start
1.9 block with 1.6 head???
skoda pickup diesel turboing??
max safe boost pressure .
Turbo independent lubrication system. Which oil?
Will ARP studs fit 1.6 block w/ 1.9 head
biodiesel question
Which one of these flywheels should I use on my Franken?
What do you need to do to upgrade from 020 to 02J?
Ha, got a TD block...
Turbo on a 1.6NA- sorry for the newbie thread
fuel injection hose?
Were all AAZ's TD?
1.6NA price
Is there a longer clear fuel line?
1.9L TD AAZ, can i have cruise control,hard to in, wer to ge
1.9td cost?
1.6TD no power
Flywheel question, need answers. Adaptor finished, Pics!
Does anyone know the weight of a stock 1.6TD con-rod?
Total seal Quickseat
New to VW diesel - couple of questions
1.6 to 2.0 TD Piston
Lots of spam
Clutch & cylinder head questions.
Newbie to the VW IDI world..But not to diesels.
ID-DI crosbreed engine thoughts
LDA grease
Air in my fuel line, small tank/filter leaking fuel
synthetic oil after 1.9L AAZ rebuilt????
Shiny
Injection pump question (UK members?)
Just making for sure...3 questions
p/s and a/c
Tuned fuel screw 1 turn - idle now 3200 rpm!!!
Which Turbo to use
ceramic coating vs. oil squirters
12mm head on 11mm bottom end
Piles of blue smoke :(
Total Newbie, injection pump questions
Differences in heads
stock VW t3 oil feed fitting
Lots of smoke...What do you think?
LDA pump cover rebuild
