Author Topic: 1.9 block with 1.6 head???  (Read 6017 times)
March 04, 2008, 04:29:27 am
Torchd
  • 372
« on: March 04, 2008, 04:29:27 am »
Can i use a 1.9TD block with a head, turbo and IP from a 1.6TD??
Will everything fit bolt on, without any alteration and what kinda results should i be looking for??
Has any one done this setup??
Help pleasee!??
Reply #1March 04, 2008, 11:37:22 pm
Torchd
  • 372
« Reply #1 on: March 04, 2008, 11:37:22 pm »
So...  it cant be done???
what happens if the compression ratio will be too high??  how can i lower it?
Reply #2March 05, 2008, 06:34:01 am
saurkraut
  • 904
« Reply #2 on: March 05, 2008, 06:34:01 am »
Quote from: "Torchd"
Put a 1.9 head on it.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #3March 05, 2008, 06:46:34 am
« Reply #3 on: March 05, 2008, 06:46:34 am »
You could also grind the pistons down, though you'd have to figure just how much to grind. But why would you want to put on a head that doesn't flow as well?
Reply #4March 05, 2008, 06:18:12 pm
« Reply #4 on: March 05, 2008, 06:18:12 pm »
it won't be too high theres alot of 1.9s with 1.6 heads on them running around.  hill folk has a mk2 with a 1.9 block and 1.6 head, its na tho.
Reply #5March 05, 2008, 09:25:33 pm
Torchd
  • 372
« Reply #5 on: March 05, 2008, 09:25:33 pm »
Hmm seen!!  i wud love to put a 1.9 head on a 1.9 block but the thing is i dont have the 1.9 head...
hmmm.....  im looking to run 1.6 MF turbo with 1.6 head and 1.9 block and will run abot 25 psi boost...  so i guess thats not possible like u guys have always said..
So if i get the 1.9 head and 1.9 block...  will the 1.6 MF turbo fit bolt onto 1.9 head? and will the IP from the 1.6TD fit as well??
Please reply soon.. i need to make the decision fast as im runnin late to order the parts..
cheers!
Reply #6March 06, 2008, 02:24:44 am
Torchd
  • 372
« Reply #6 on: March 06, 2008, 02:24:44 am »
assuming the IP fits.....   what injectors will i be using??  1.9TD injectors?  or 1.6TD injectors??  with 1.6td pump...??
Reply #7March 07, 2008, 04:07:42 am
Torchd
  • 372
« Reply #7 on: March 07, 2008, 04:07:42 am »
Guysssss???
Can some one pleaseeee reply???
Vincee?
Andrew?
Reply #8March 07, 2008, 05:54:34 am
« Reply #8 on: March 07, 2008, 05:54:34 am »
If it's a 1.9, why would you want to use 1.6 injectors? However it will run with either.
Reply #9March 07, 2008, 11:00:41 pm
Torchd
  • 372
« Reply #9 on: March 07, 2008, 11:00:41 pm »
Cuz...  the IP is from a 1.6TD... but the head and block are of a 1.9....  so im confused!
Reply #10March 08, 2008, 05:51:59 am
« Reply #10 on: March 08, 2008, 05:51:59 am »
Use the 1.9 injectors.
Reply #11March 08, 2008, 03:53:33 pm
oldskool rich
  • 446
« Reply #11 on: March 08, 2008, 03:53:33 pm »
well in my eyes the 1.6 injectors hav slacker springs so you can deliver more fuel, thats what i run although if sumone can tell me im wrong please do.
audi80s 225bhp aaz is running a 1.6 head, 1.9 block, 1.6 injectors
my mate thinks that the 1.6 head increases the gas speed and higher compression is a good thing too, aaz gasket should hold
tbh your probly best speaking to some one thats done it already
f6squared I.D.S.T
Reply #12March 08, 2008, 04:08:11 pm
Mexe
  • 22
« Reply #12 on: March 08, 2008, 04:08:11 pm »
My friend is running a 1.9 block with a 1.6 head and 1.6 GTD injectors. He has had no problems with it and is running at least 22 psi if not more by now. The thing goes and as his dad says runs circles around their chipped Mk4 TDI Jetta.
Reply #13March 09, 2008, 11:43:45 pm
Torchd
  • 372
« Reply #13 on: March 09, 2008, 11:43:45 pm »
Quote from: "Mexe"
Which IP is he using????
Reply #14March 09, 2008, 11:45:11 pm
Torchd
  • 372
« Reply #14 on: March 09, 2008, 11:45:11 pm »
Quote from: "oldskool rich"
Which IP is he using????  and The audi 80 u are talking about...  hasn't that guy already done it??
