Author Topic: 1.9 block with 1.6 head???  (Read 6068 times)
Reply #15March 10, 2008, 02:00:28 am
MJF
  • 581
« Reply #15 on: March 10, 2008, 02:00:28 am »
My head and bottom end is highly modded, so itŽs better not to compare it to stock engines. IŽm using modded 1,6 IP
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #16March 10, 2008, 03:23:23 am
Torchd
  • 372
« Reply #16 on: March 10, 2008, 03:23:23 am »
Seen...
So MJF...  You were/are using 1.9 block, 1.6 head and 1.6IP..... which brackets are you using to mount the 1.6 IP on to the 1.9 block??  as vince valdon said that 1.6 IP doesnt mount on the 1.9 block; timing belt cant be aligned....
so what have u done??  as i wana use a 1.9 block with 1.6 IP... and im still think about which head to use..  either the 1.6 or the 1.9 head.
Reply #17March 10, 2008, 03:44:26 am
MJF
  • 581
« Reply #17 on: March 10, 2008, 03:44:26 am »
1,6 pump brackets, will bolt to 1,9 block. Use 1,9 head.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #18March 10, 2008, 11:01:07 pm
Torchd
  • 372
« Reply #18 on: March 10, 2008, 11:01:07 pm »
Thanks MJF..
so you mean i can use the following setup without any alteration??
1.9 block
1.9 head
1.6 turbo
1.6 TD IP (using 1.6 brackets on 1.9 block)
1.6 TD injectors
and which timing belt and timing belt adjuster am i suppose to use?
Please confirm.
Thanks again!
Reply #19March 11, 2008, 05:52:15 am
MJF
  • 581
« Reply #19 on: March 11, 2008, 05:52:15 am »
YouŽll need early 1,9 injector lines, becouse of shorter 1,6 injectors. Some early (or ecos?) 1,9 had short injectors too. I like to use manual adjuster from 1,6 and early 1,9 and youŽll need 1,9 belt.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #20March 11, 2008, 10:32:10 pm
Torchd
  • 372
« Reply #20 on: March 11, 2008, 10:32:10 pm »
So i use the 1.9 timing belt...
"I like to use manual adjuster from 1,6 and early 1,9"  What are manual adjusters??....
Thanx for the rest... but didnt get this one?!
Reply #21March 13, 2008, 01:42:26 am
Torchd
  • 372
« Reply #21 on: March 13, 2008, 01:42:26 am »
MJF...
waiting for your response!?
