1.9 block with 1.6 head???
Pages:
Topic: 1.9 block with 1.6 head??? (Read 6070 times)
Reply #15
March 10, 2008, 02:00:28 am
MJF
Reply #15 on:
March 10, 2008, 02:00:28 am »
My head and bottom end is highly modded, so itŽs better not to compare it to stock engines. IŽm using modded 1,6 IP
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #16
March 10, 2008, 03:23:23 am
Torchd
Reply #16 on:
March 10, 2008, 03:23:23 am »
Seen...
So MJF... You were/are using 1.9 block, 1.6 head and 1.6IP..... which brackets are you using to mount the 1.6 IP on to the 1.9 block?? as vince valdon said that 1.6 IP doesnt mount on the 1.9 block; timing belt cant be aligned....
so what have u done?? as i wana use a 1.9 block with 1.6 IP... and im still think about which head to use.. either the 1.6 or the 1.9 head.
Reply #17
March 10, 2008, 03:44:26 am
MJF
Reply #17 on:
March 10, 2008, 03:44:26 am »
1,6 pump brackets, will bolt to 1,9 block. Use 1,9 head.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #18
March 10, 2008, 11:01:07 pm
Torchd
Reply #18 on:
March 10, 2008, 11:01:07 pm »
Thanks MJF..
so you mean i can use the following setup without any alteration??
1.9 block
1.9 head
1.6 turbo
1.6 TD IP (using 1.6 brackets on 1.9 block)
1.6 TD injectors
and which timing belt and timing belt adjuster am i suppose to use?
Please confirm.
Thanks again!
Reply #19
March 11, 2008, 05:52:15 am
MJF
Reply #19 on:
March 11, 2008, 05:52:15 am »
YouŽll need early 1,9 injector lines, becouse of shorter 1,6 injectors. Some early (or ecos?) 1,9 had short injectors too. I like to use manual adjuster from 1,6 and early 1,9 and youŽll need 1,9 belt.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #20
March 11, 2008, 10:32:10 pm
Torchd
Reply #20 on:
March 11, 2008, 10:32:10 pm »
So i use the 1.9 timing belt...
"I like to use manual adjuster from 1,6 and early 1,9" What are manual adjusters??....
Thanx for the rest... but didnt get this one?!
Reply #21
March 13, 2008, 01:42:26 am
Torchd
Reply #21 on:
March 13, 2008, 01:42:26 am »
MJF...
waiting for your response!?
Pages:
