Author Topic: Is there a longer clear fuel line?  (Read 3013 times)
March 09, 2008, 01:32:40 pm
suededub
  • 7
« on: March 09, 2008, 01:32:40 pm »
Hello,
I have a '79 Rabbit, that I converted to a 1.6TD about 7 months ago, and have been loving. However, I'm redoing the engine bay now, and would like to relocate the fuel filter to the back side of the strut tower.
Here's a pic of my engine bay and an arrow to help explain...
So basically, I need a clear line that's about 6-10" longer so I can bolt it to the back of the strut tower instead of the front, and still have the slack needed.
Thanks all,
Erik
'79 Rabbit 1.6TD
'77 Derby 1.3
Reply #1March 09, 2008, 01:44:31 pm
Quantum TD
  • 1195
« Reply #1 on: March 09, 2008, 01:44:31 pm »
The stock line with the fitted ends is still available. Here is the part number:
068 130 309
Maybe you can buy two and mate them together?
Reply #2March 09, 2008, 01:48:51 pm
burnt_servo
  • 278
« Reply #2 on: March 09, 2008, 01:48:51 pm »
i put a fuel pump where your filter is right now , then i relocated the filter a few inches towards the motor , and down, below the intake hose .
you shouldn't need new hoses to do that .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #3March 09, 2008, 02:19:41 pm
suededub
  • 7
« Reply #3 on: March 09, 2008, 02:19:41 pm »
I could have swore I saw a picture recently of a mk1 that had the filter right where I want to move it to, but with a stock looking line, but I can't seem to find it...
'79 Rabbit 1.6TD
'77 Derby 1.3
Reply #4March 09, 2008, 02:33:43 pm
  • 1739
« Reply #4 on: March 09, 2008, 02:33:43 pm »
It would on a 83-84 jetta  td. If i remember they had the filter on the firewall.
Reply #5March 09, 2008, 03:36:36 pm
Luckypabst
  • 502
« Reply #5 on: March 09, 2008, 03:36:36 pm »
My 81 Caddy has it about halfway to where you want yours. There's quite a bit of slack left - you could probably squeak a bit more rotation out of the filter location.
Chris
'82 TD Westy
'81 NA Caddy
Reply #6March 09, 2008, 03:44:00 pm
suededub
  • 7
« Reply #6 on: March 09, 2008, 03:44:00 pm »
Mine was in the same spot as yours originally, but I had to relocate it forward when I swapped in the TD, you can still see the factory mounting studs where it was. It didn't have enough slack to make it to the back of the strut tower.
I'll have to check on the the 83-84 TD line. Does anyone have a part number for that, btw?
'79 Rabbit 1.6TD
'77 Derby 1.3
Reply #7March 11, 2008, 11:59:29 am
« Reply #7 on: March 11, 2008, 11:59:29 am »
I got my hose at napa and it's just like what came on my rabbit. I just wanted new hose and the stuff they had was perfect and has been fine for the two years I've used it.
Reply #8March 11, 2008, 02:07:35 pm
suededub
  • 7
« Reply #8 on: March 11, 2008, 02:07:35 pm »
NAPA has the clear line? I hope so, that'd be convenient. :D
'79 Rabbit 1.6TD
'77 Derby 1.3
Reply #9March 11, 2008, 02:51:29 pm
dieseldunebuggy
  • 24
« Reply #9 on: March 11, 2008, 02:51:29 pm »
I got my clear fuel line at my local lawnmower shop. Works perfect!
1981 Volkswagen Rabbit L custom 1.6l N/A
-Stainless Steel Header
-Huge Custom Intake
-Ported Head
-Lightened Flywheel
-ARP Headstuds
-GILES PUMP
Reply #10March 11, 2008, 03:12:28 pm
KTZed
  • 170
« Reply #10 on: March 11, 2008, 03:12:28 pm »
Get polyurethane, not pvc (vinyl). pvc wont take the heat and the urethane is much more abrasion resistant.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
