» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Head rests on MKIII rear seats..?
Fuel solenoid wiring
Piston Diagnosis Help - Photos-
Haven't been driving my car for a while, cooling issues
can someone find which engine
No. 1 cylinder
EGR system retrofit
WHen was it introduced?
aaz pump on a 1.6
New 1.6TD IP only pumping out of two holes.
Need help identifying NA pumps
timing belt +
Cheap instrument pod
Cleaning carbon crud from pistons / piston ring grooves
Source for IDI TD pistons (1mm oversize)
engine oil priming after rebuild
tunning aaz
Since its already torn appart... what should i do?
Removing and Installing Prechamber Inserts
torque settings
V-belt pulleys
Who is this Prothe fellow?
AAZ Clutch source
82 Rabbit tach
Buying Timing Belt Kit and Tools for 1.6L NA
AAZ T3 smoke issues.
NA Headgasket
Took me long enough
power steering delete
DIY propane injection?
gas camshaft?
Leaky....
ARP head stud specs
flywheel bolts
Wich Cam-plate for AAZ pump?
Melt Down
Show us your IDI ride!
How to remove camshaft sprocket?
Compressor diesel? more power from diesel
AAZ injector change
ra/sb pistons
Quick TD clutch question
Idle Boost w/ A/C?
A/C recharge kit?
engine cuts out at high revs
IP bracket bolts loosening up
Turbo Question
K03 leaing oil!
Checking axial (thrust) clearance on 1.6 TD crankshaft
Nuts and bolts question
