aaz pump on a 1.6
Topic: aaz pump on a 1.6 (Read 1950 times)
July 29, 2008, 04:42:09 pm
dillenger1
aaz pump on a 1.6
July 29, 2008, 04:42:09 pm »
Guys what kinda problems will i run into with this?I know i have to swap delivery valves,for the shorter 1.6 type. anything else?
1.6td in toyota pickup
10mm head ,t3 intercooled.
July 29, 2008, 04:46:30 pm
aaz pump on a 1.6
July 29, 2008, 04:46:30 pm »
the pump nose sticks out more, but i think if you use the 1.9 pump sprocket you should be ok. AFAIK you need the 1.9 pump bracket too.
July 30, 2008, 03:18:56 am
dillenger1
aaz pump on a 1.6
July 30, 2008, 03:18:56 am »
what about using a main shaft from a 1.6?What doesnt line up with the bracket?I thought all the triangle mounts were the same cast.
July 30, 2008, 04:33:13 pm
dillenger1
aaz pump on a 1.6
July 30, 2008, 04:33:13 pm »
Did the 1.6td ever come with the timing accelerator?(solenoid on side like aaz0.Ive got this pump core and its got a 1.6td pin in the lda,and looks like its never been removed(yellow dot).The numbers are:0-460-404-200
R 254-bs401
068 130 110n
aaz pump on a 1.6
