Author Topic: Cleaning carbon crud from pistons / piston ring grooves  (Read 2190 times)
July 28, 2008, 07:34:27 pm
captainpartytime
  • 39
« on: July 28, 2008, 07:34:27 pm »
What is the best way to clean the carbon crud off of my pistons and piston ring grooves?
-Kerry
1982 Diesel Westfalia Vanagon
1989 Wolfsburg 7-Passenger Vanagon
Reply #1July 28, 2008, 09:24:00 pm
« Reply #1 on: July 28, 2008, 09:24:00 pm »
A carbide piston ring groove cleaner  with the right size cutter is the safe way to do the ring grooves.... it's a sealing surface and so needs to be cleaned very accurately.
For the face of the piston... I actually cheat and use a wire brush... but I'm very careful to get nowhere near the edge where I might scrape a groove in the side.
Reply #2July 29, 2008, 07:45:50 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #2 on: July 29, 2008, 07:45:50 pm »
I have used the old rings to clean the ring grooves. You will need to file/grind and edge to be able to pick at it to get the crud off. If you did it right, you will have numerous cuts on your thumb :)
Reply #3July 30, 2008, 08:04:58 am
fastvicar
  • 154
« Reply #3 on: July 30, 2008, 08:04:58 am »
I must have done it very right.  :(
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
