Removing and Installing Prechamber Inserts
Topic: Removing and Installing Prechamber Inserts (Read 2289 times)
July 28, 2008, 08:47:33 pm
bluemotion
User+
July 28, 2008, 08:47:33 pm »
What is the best way to remove and install the prechamber inserts on the 1.6 diesel heads?
July 28, 2008, 09:19:56 pm
July 28, 2008, 09:19:56 pm »
Hammer and a drift, put drift down through the injector hole and hit it. Line up and tap back in when done, peen around it and your done.
July 28, 2008, 09:50:37 pm
July 28, 2008, 09:50:37 pm »
Quote from: "libbybapa"
The best way is to leave them alone unless absolutely necessary.
Andrew
This is true, I was going to ask why you wanted to remove them.
The head can and should be machined with them in place.
