Author Topic: Turbo Question  (Read 1892 times)
July 22, 2008, 05:20:42 pm
  • 3468
    • McScrubbins Body Wash
Turbo Question
« on: July 22, 2008, 05:20:42 pm »
how can you tell if you have a k24 or a garret turbo?
my year is 1990 on an mk2 jetta
cheers
Reply #1July 22, 2008, 07:02:17 pm
Turbo Question
« Reply #1 on: July 22, 2008, 07:02:17 pm »
More than likely you have a K24
Reply #2July 23, 2008, 05:06:54 am
Torchd
  • 372
Turbo Question
« Reply #2 on: July 23, 2008, 05:06:54 am »
Remove the air intake pipe and you should be able to see a blue plate on the compressor housing with all the details....
If its a K24 then the plate will be on the back side of the compressor housing or it mite not be there... u can tell by looking at the numbers on the housing if they are 5342......   then its a K24.
