View full version: IDI Engine
  1. Runaway truck! Breather mod questions...
  2. 1.9tdi 130pd awx intake manifold in 1.6td?
  3. Would a TDI cylinder head fit on a IDI block?
  4. my 1.6L rebuild and upgrade
  5. egr valve question
  6. Exhaust manifold diameter question
  7. 1.6 td gearbox
  8. Turbo Size??
  9. QUICK fast as you like form a orderley queue
  10. Golf 1.9 TD overheating
  11. Main caps stretch bolts?
  12. belt ???'s
  13. Crankshaft install tips?
  14. How much boost can I run on stock turbo and be reliable?
  15. Dasher upgrade to Quantum TD 5spd
  16. Bare cyl. head or rebuild??
  17. 1.6td questions
  18. Inlet manifold bummer... Or not??
  19. 1.6 TD Jetta Coupe
  20. Where to get tranny selector shaft boot?
  21. VNT15 outlet flange
  22. We sell and Buy iframe traffic.
  23. Which valve cover gasket do i want?
  24. turbo compairison
  25. 84 turbo diesel
  26. hydraulic lifters
  27. 1.6 TD Questions
  28. T2 or T3?
  29. Strange buildup
  30. AAZ Clutch suggestions ?
  31. 1.6td swap ???'s
  32. IP timing and dyno
  33. 1.6NA IP vs 1.9IP
  34. The governor mod in the fuel injection pump
  35. NA pump to turbo conversion
  36. What tranny for AAZ in a Mk 1 ??
  37. Why is my GTD running so well?
  38. questioning vortex info
  39. Should I pull the head?
  40. IP rebuild
  41. Symptoms of a tired injection pump.
  42. 1.6 NA crank pulley
  43. Garrett t3 upgrade help needed
  44. 1.9td over heating
  45. Help me about finance.
  46. quantum muffler deletion
  47. Where to get injector heat shields?
  48. Quick help please: setting timing on AAZ dual piece pump
  49. How has ULSD affected your pump?
  50. G-Teched my 1.6TD - Baseline Runs
