Author Topic: Crankshaft install tips?  (Read 2923 times)
April 06, 2007, 11:10:52 am
b1rdjx88
« on: April 06, 2007, 11:10:52 am »
I am installing my aaz crank with new bearings this weekend and I'm wondering if there  are any pitfalls to watch out for?  I have never done this  before
Specifically I am wondering:
-Must the bearing shells be aligned in the caps and block bores somehow or can I just eyeball it?
-Bearing to block and bearing to cap surfaces should be dry, correct?
-Bolts go in dry?
-Is it okay to use a bit of motor oil to adhere the thrust bearings to the block while I drop the crank in?
My plan is to put it in, check clearances with plastigage, spread some oil on the journal surfaces, seat the thrust bearings by prying forward / backward and then torque it down incrementally on all bolts.  I'm using new bolts.  Anything else?
Thanks,
Alan
Reply #1April 06, 2007, 11:20:45 am
SMOKEYDUB
  • 630
« Reply #1 on: April 06, 2007, 11:20:45 am »
the bearings will align there selves they have little tabs on them for that and the bearing will hold itself in because it is actually slightly bigger then the block. becareful and good luck..
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2April 06, 2007, 01:57:45 pm
myke_w
  • 1099
Re: Crankshaft install tips?
« Reply #2 on: April 06, 2007, 01:57:45 pm »
Quote from:
Sounds A ok to me
Reply #3April 09, 2007, 03:56:41 pm
b1rdjx88
« Reply #3 on: April 09, 2007, 03:56:41 pm »
So all went well, I got the engine back together and then I double checked the torque on th wrench I used by comparing with a smaller beam style wrench I have.  It turns out I torqued all bolts 10ft-lbs too high!! :oops:
    I put the car back together anyways, and this next weekend I plan to take the pan off install new bolts with correct torque.
     Is this really necessary though?  I am thinking that the stretch bolts  get deformed in the extra quarter turn anyway.  This overtorque has simply caused the bolts to go through a greater plastic deformation.  As long as I didn't torque them past the ultimate tensile strength they should still be plenty strong.  I read somewhere else that stretch bolts normally only undergo 2-3% plastic deformation.
Any thoughts?  Also why does the horn now go off when I try to connect the battery?
Thanks for helping a newbie along,
Alan
Reply #4April 09, 2007, 04:41:42 pm
SMOKEYDUB
  • 630
« Reply #4 on: April 09, 2007, 04:41:42 pm »
i would bet the bolts would be fine i wouldnt really worry about them. As for the horn i am assuming you have a MK3 then that would be your theft alarm and you should be able to just lock and unlock your doors using the key and it should go off. If its and mk2 i had a problem like that were i had 2 wires on the starter mixed up.
(courtesy of GILES)
Reply #5April 10, 2007, 02:35:48 am
jimbrown618
  • 43
« Reply #5 on: April 10, 2007, 02:35:48 am »
Here's a link to the Bentley VW forum regarding the alarm:
http://tech.bentleypublishers.com/thread.jspa?forumID=39&threadID=16858&messageID=150980#150980
Essentially you need to have the key in the ignition & turned to on when you hook up battery.
