turbo compairison
Topic: turbo compairison (Read 2421 times)
April 06, 2007, 08:03:02 pm
turbo compairison
April 06, 2007, 08:03:02 pm »
Check out the pics,
I have a little un named turbo with a
39.5 mm 10 blade inducer and 58.7mm exducer (cleaner one)
The blades on this one are deeper, top of blade to base is longer than the kkk.
The second turbo is a kkk, K-24 with a
36.2 mm 12 blade inducer and 60.3mm exducer
The un named turbo has a Stainless exhaust housing and the kkk is cast.
I was unable to get the exhaust housing off the kkk to compare the exhaust turbine.
The kkk compressor housing seems to be built for more flow as in it's more open inside, the un named turbo is more congested.
It's un named because there are NO marking to tell me what it is. The tag is gibberish and there are no A.R. markings on either housing although it looks about the same size.
So, with this info and the pics provided which do you believe would be better for the Jetta?
Leaning towards the kkk because it will bolt on but the features on the other turbo are appealing like the ss housing.
Sorry for the blurry pics, had to use my phone.
On another note, what are the differences between the K-24 and the K-14, anyone?
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2808&d=1175914674
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2809&d=1175914674
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2810&d=1175914674
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2811&d=1175914715
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2812&d=1175914715
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2813&d=1175914715
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2814&d=1175914747
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2815&d=1175914747
http://www.competitiondiesel.com/forums/attachment.php?attachmentid=2816&d=1175914747
turbo compairison
