Author Topic: 84 turbo diesel  (Read 4342 times)
April 05, 2007, 04:35:28 pm
boosted_diesel_84
  • 216
84 turbo diesel
« on: April 05, 2007, 04:35:28 pm »
alright i have a 84 turbo diesel 1.6, it has a KKK turbo, but not sure if its a k14 or k24, whats the difference? and are they much different than a k26? and how do you adjust the boost? i found a threaded shaft in the middle of the wastegate with a nut on it, and a 3mm allen wrench fits in the shaft,do i tighten the shaft or loosen it to increase boost? or is it possible to put a boost controller on it to adjust from inside the car? thanks for your help!
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #1April 05, 2007, 05:33:25 pm
xud9te
  • 88
84 turbo diesel
« Reply #1 on: April 05, 2007, 05:33:25 pm »
Always shorten the shaft to increase boost.  This will increase the pre-load on the diaphragm spring and make it require more load to start moving!
A bleed valve can be used as well, this will hide a percentage of the boost from the diaphragm and have a similar effect, although having long lines inside the car will theoretically give boost spikes.
Best to shorten the rod by 1 turn, test, and repeat until you have the desired boost level..  You need a guage.
Reply #2April 05, 2007, 06:35:14 pm
84 turbo diesel
« Reply #2 on: April 05, 2007, 06:35:14 pm »
Being a mk1 it is most likely a K14, it is a smaller turbo then the K24 and will build boost at much lower RPMs. I don't know about K26s
Reply #3April 05, 2007, 07:08:24 pm
84 turbo diesel
« Reply #3 on: April 05, 2007, 07:08:24 pm »
really? All of my post 90 TDs have been K24s and I've heard that the mk1s had the K14s and Eco diesels always came with the K14
Reply #4April 06, 2007, 04:59:59 am
Patrick
  • 1034
84 turbo diesel
« Reply #4 on: April 06, 2007, 04:59:59 am »
Got an '85 in the back yard with a K24......
  a factory rebuild I took out of an '87 with a K24.........
Everything else (92's) (except the AAZ in my 92, K14)  had a Garrett t-3
Reply #5April 06, 2007, 05:33:30 am
84 turbo diesel
« Reply #5 on: April 06, 2007, 05:33:30 am »
all 1.6 true tds accept for in europe came with a t3 or k24.
Reply #6April 06, 2007, 05:45:17 am
84 turbo diesel
« Reply #6 on: April 06, 2007, 05:45:17 am »
crap. I was really hoping my mk1 TD I just bought came with a K14, there goes that plan.
Reply #7April 06, 2007, 07:00:43 am
Dr. Diesel
  • 1341
84 turbo diesel
« Reply #7 on: April 06, 2007, 07:00:43 am »
def a K24 or T3.
A k14 would be far more suitable for a 1.6L though.
Reply #8April 06, 2007, 09:28:46 am
myke_w
  • 1099
84 turbo diesel
« Reply #8 on: April 06, 2007, 09:28:46 am »
A stock '84 would have the K24.  The K14 was not used until '90.  The K26 would be WAY TOO BIG for a stock 1.6TD.
Andrew
Ditto
Reply #9April 06, 2007, 10:08:23 am
subsonic
  • 1836
84 turbo diesel
« Reply #9 on: April 06, 2007, 10:08:23 am »
Why would the k14 be better?  Would that be for quicker spool and more low end boost? Both of my MF 1.6TD's came with a t3 and k24, respectivly and not as a twin set up of course. :)
Reply #10April 06, 2007, 11:24:25 am
SMOKEYDUB
  • 630
84 turbo diesel
« Reply #10 on: April 06, 2007, 11:24:25 am »
you got it the 1.6 in stock form with a t3 or k24 is to laggy i think almost any of the turbos that came on the 1.9 would behave amazingly on a 1.6. I would love to try a k03 on my daily 1.6.....hmm maybe i will.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #11April 06, 2007, 07:59:16 pm
ODwyerPW
  • 103
    • http://www.Espanglish.com.mx
84 turbo diesel
« Reply #11 on: April 06, 2007, 07:59:16 pm »
My 83 Rabbit Turbo Diesel has the K24.  I like it , but yes there is substantial lag.
83 Rabbit LS Turbo Diesel
Reply #12April 06, 2007, 08:01:20 pm
84 turbo diesel
« Reply #12 on: April 06, 2007, 08:01:20 pm »
i find that there isn't too much lag... once the engine is warmed right up, the lag is only about 1-2 seconds at most.  i can only see the turbo shaft wearing down quite a bit from that kind of abuse though!!! hehe
