Author Topic: 1.6td questions  (Read 2286 times)
April 09, 2007, 06:34:35 am
whb
  • 1
1.6td questions
« on: April 09, 2007, 06:34:35 am »
hello everyone i'm new to this forum and from what i can see
this is were to come for any diesel questions!!!
i just purchaced an 84 rabbit L diesel with a 1.6
my friend is swapping his 91 jetta td engine to a vr6 so i'll be buying his
1.6td engine from him to put in my rabbit.
now my questions are
 with the engine out (has 320 000 km on it)
i would really like to rebuild completly. i wont be doing it myself
so how much am i looking to pay if it done by a mechanic? and what parts
would need to be changed besides timming belt and water pump?
also what upgrades should i do for more power
i'm not looking for crazy horsepower! looking to get 150 to 170
or is that too much to ask for.
any help will be greatly appreciated
Reply #1April 09, 2007, 02:25:20 pm
veeman
  • 421
1.6td questions
« Reply #1 on: April 09, 2007, 02:25:20 pm »
>i wont be doing it myself so how much am i looking to pay if it done by a mechanic?
I guess that all depends on what the mechanic charges per hour and what his markup is on the parts to do the job.  If I were going to rebuild one myself with that mileage, I'd probably have the block bored out to the next oversize piston, then buy all new bearings, new pistons /rings and the gasket set.  I'd count around $900 US or so with the machine work plus the labor to assemble it.   That's just an estimation since some machine shops seem to do the work a bit cheaper than others.
Has the head ever been rebuilt?  I'd say it's due unless you just want to run it "as is".  You can have yours rebuilt or find a good used one for less... figure around $200-$600 depending on which strategy you're going for.  Add in some extra cash for head studs if you're planning on running high boost.
Next... how's the turbo?  Any play in the turbo shaft?  You might have someone check it out and have the bearings replaced / shaft balanced.  Seems like I spend around $350 minimum every time I have that done.
What else?  If you're shooting for big power, you should probably plan on a good clutch setup / disk at the same time.  Add around $125  for a light flywheel and another some more money for a new pressure plate and a good quality disk.
While everything's apart, I'd definitely also have your injectors rebuilt / nozzles replaced.  I'd say plan around $30-40 each to do that.  How's the pump?  Any leaks or anything?
Now... if you're paying a mechanic to do all that, you'll probably really have to get a good idea of what he'll charge up front or how many hours it'll take.  The prices above were just for the parts / services, not assembly or installation.
The sky and your wallet are pretty much your limits there.  You could do some real basic pump tweaks, add an intercooler and a good exhaust / downpipe setup and end up with over 100hp and a lot of torque.  Mine's around there now and it's a lot of fun to drive and still gets good mileage.
If you really want more power (who doesn't?) you could send your pump off to Giles or someone else to have it modified ($8-900 US) and then start messing around with fueling, special cams (PP), more agressive turbos and manifolds / headers.  Unfortunately, this type of project adds up quickly.
Don't want to discourage you, but building a relatively high-power TD can be a somewhat expensive prospect.
Hope that helps...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #2April 09, 2007, 03:01:19 pm
1.6td questions
« Reply #2 on: April 09, 2007, 03:01:19 pm »
veeman has it bang on!
you might also want to consider getting the oil pan baffle (it is listed as a 1.9TD AAZ engine code oil pan baffle (it has a re-useable rubber gasket on it too!) and a new oil pump as cheap insurance.
myke_w has some of the best prices for oil pumps, quality Goetz rings, and Kollbenschmidt pistons.  Don't cheap out and buy crappy parts.  Go with quality and it will last you a long time!
150hp is attainable, but for that, have your pump sent to Giles (check vendor's section).  You will also need a nice big intercooler, and a nice downpipe from www.passengerdiesel.com, or fab up your own.
aircraftspruce sells a nice EGT thermocouple and gauge for around $80 that is very responsive to boost temperature, which will help you determine if you are going to cook your motor or not.
rebuilding the head is also a great idea.
