Should I pull the head?
Topic: Should I pull the head? (Read 3279 times)
March 31, 2007, 09:19:48 pm
b1rdjx88
March 31, 2007, 09:19:48 pm »
I have just taken the crankshaft out of my 1.9 and it will be machined for the TDI gear this week.
While pulling the engine I accidentally bumped the number 4 piston (I think) against the valves a couple times. This happened when I was unbolting the inner CV joints. I had already taken the timing belt and crank gear off before pulling the engine and I thought the transmission was in neutral when I started wrenching the CV joint bolts... I Know I know - definitely won't be making that mistake again!
There was no sharp impact. I think at most 20ft-lbs would have been applied to the CV bolt while the piston and valve were in contact.
So should I pull the head to check for a bent valve? My plan had been to just close up the bottom end with new bearings. The engine ran quite well just before I tore into it.
March 31, 2007, 09:39:44 pm
March 31, 2007, 09:39:44 pm »
HG jobs aren't too bad with the engine installed. I'd try it as is and then if the compression is low or it idles really rough I'd pull the head
April 01, 2007, 07:15:49 am
rwest1
Newbie
April 01, 2007, 07:15:49 am »
I strongly doubt that level of valve to head contact would cause a problem. I would finish the lower end rebuild, then hand crank the engine through, checking valve operation/clearance. Unless I found a problem I would close it up and move on. I’ve seen the old 1.5’s that were just starting to chew up the keyway run along making a big doink sound every once in a while (piston hitting valve). If you caught it fast enough you could save the head/valves. Regards
April 01, 2007, 09:50:17 am
Wingaman
April 01, 2007, 09:50:17 am »
Don't worry about that.
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
April 01, 2007, 02:02:09 pm
idgtd
April 01, 2007, 02:02:09 pm »
A friend of mine with a VW diesel/samurai conversion had his T-belt jump timing while the engine was idling in his yard. We pulled the head, and no damage was found. The belt had a 14in section with no teeth on it.
Stephen Phillips
1981 VW Rabbit Diesel (mit turbolader)
1985 VW Scirocco Wolfsburg Ed.
1970 Porsche 911T
1972 MG Midget
1996 Chevy C3500 Dually
1930 Model A Ford
April 01, 2007, 02:59:34 pm
Wingaman
April 01, 2007, 02:59:34 pm »
One of mine mecano forgot the lockpin on the pump on a Eurovan 2.4 Diesel (T4) and the cam timing belt slip (not the pump timing belt) when cranking and no damage was found.
We pulled the head for nothing :roll:
April 01, 2007, 06:18:30 pm
tylernt
April 01, 2007, 06:18:30 pm »
I don't think you could damage the valves with the pistons using hand power if you tried.
April 02, 2007, 05:44:50 pm
b1rdjx88
April 02, 2007, 05:44:50 pm »
Is that a challenge?!
Thanks for the reassuring replies. I will button it up this next weekend and see how it goes.
Any tips for holding the water pump pulley in place while bolting it back on the pump? I got it off no problem using two wrenches to loosen two bolts and then wedging a long bar between the two loose bolts and the floor to get the last one, but I don't know if this will work in reverse.
Also can I get away with using RTV sealant on the old oil pan gasket/baffle or do I need to buy a new ($) one?
Thanks,
Alan
April 02, 2007, 08:56:10 pm
April 02, 2007, 08:56:10 pm »
Use one of those BOA straps to hold the pulley, shouldn't have any problems.
The baffles are rubber are they not? That would mean they are reusable
