» IDI Engine
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Timing belt "time" limit??
Calling anyone who VW diesel'ed a Suzuki or Toyota
Ip from Giles
1.6TD into A3 Golf? good idea? bad idea?
Which Engine?
This week is over for me, at last...
feul cut higher in rpm (governermod related)
Anyone know about these nozzles?
Kolbenshmidt TD Pistons
WOT mid to high RPM cut out???
1.7 mech block to 1.6 hydro head
pump timing HELP!!!
How much power with your 1.9 TD ??
clutch is slipping at 20psi need a new clutch please help
AAZ Belt Tensioner
Exhausting AAZ questions...
Benefits of an inline fuel pump
Oil Pressure Problems..................HELP!
colorado biodiesel injectors ??
Top mount intercooler?
85 Mechanical TD Oil Pump
K14 spool-up
Intercooler ideas and pictures
Saab 900 Intercooler
rebirth of the the GTD
argh, k24 waste gates stuck any suggestions to get it loose?
GTD injectors installed!!
Rod bearings
Valves: VolvoD24/VW interchangeable?
water-cooled intake manifold
VE Pump Identification
just to share my GTD build(not just engine...)
Tuning pins?
Oil on rocker cover?
AAZ Piston Damage question
B3 Audi or Passat Intercoolers?
My first GTD's latest mods (big surprise!)
Power Figures?
AAZ cold start mech
photos of Garrett T3 on AAZ in van
My MK2 GTD
Engine Swap 1.6NA to 1.6 Turbo
Turbo issue
One Speed Engine: Fast
just cause i like to show off...
pics of garret T2 and how to up the boost?
Engine compatability
Golf 1991 GTD 1.6 - MORE POWER?
Oil temps?
cold start, sh** happens
