Author Topic: GTD injectors installed!!  (Read 4961 times)
January 17, 2007, 05:07:55 pm
zagarus
  • 619
« on: January 17, 2007, 05:07:55 pm »
Well i got the GTD injectors from kermatdi installed (i think they are 1.9azz injectors, people have told me both)  but either way they feel gooooood!  Now i cant wait to mount me intercooler, up the boost somemore, get my exhaust done and haul some ass!!!  :lol:  :lol:
k im done.
Oh ya and i need/want/must have a giles pump so once i have enough saved for that im gettin one :D
the car they went into
Reply #1January 17, 2007, 07:22:07 pm
wolfsburgnut
  • 126
« Reply #1 on: January 17, 2007, 07:22:07 pm »
Wow, that car is poster material.  Awesome work!
Peter
1995 Golf 1.9
1994 Golf Marathon
1990 Golf 1.8
1986 Golf Wolfsburg Ed.
Reply #2January 17, 2007, 10:05:20 pm
« Reply #2 on: January 17, 2007, 10:05:20 pm »
I really like that front bumper, what year is that sweet looking car of yours?
Reply #3January 17, 2007, 10:32:51 pm
zagarus
  • 619
« Reply #3 on: January 17, 2007, 10:32:51 pm »
check the signature  :P
thanks for the comments guys, but its nothing to what i feel for the added bit of power...i wonder if the injectors were ever replaced or looked at since 1991 :?:
Reply #4January 18, 2007, 02:50:46 am
carrizog60
  • 978
« Reply #4 on: January 18, 2007, 02:50:46 am »
are the 1.9 a bolt on on 1.6td?
if i replace should i go for 1.6 gtd(SB) or 1.9 aaz dual stage injectors?
Portugal
Reply #5January 18, 2007, 01:14:27 pm
anarchyx34
« Reply #5 on: January 18, 2007, 01:14:27 pm »
They feel good in what way?
Reply #6January 18, 2007, 01:37:52 pm
« Reply #6 on: January 18, 2007, 01:37:52 pm »
anarchy i think you should get your injectors done...  you were saying your economy was suffering.  i've got my injectors back from Smog and want to install them asap.  i've bought 2 spare sets of heat shields too... and a new fuel filter :)
my guess is the butt dyno will reveal much added power!!!  :lol:
Reply #7January 18, 2007, 09:34:51 pm
zagarus
  • 619
« Reply #7 on: January 18, 2007, 09:34:51 pm »
oh ya, certainly a nice increase in power, going up hills and such. Have yet to see how the mileage was affected but hopefully for the better
Reply #8January 18, 2007, 09:47:07 pm
« Reply #8 on: January 18, 2007, 09:47:07 pm »
Quote from: zagarus
i can see mileage go up by... a lot!  i can imagine that worn out injectors would affect timing ever so slightly, and that would dramatically affect mileage/performance.  not to mention that i have been noticing some weird fluctuations in my oil level the past little while... such as oil going up when i'm not adding oil... and i know its not coolant.  coolant level has not budged one bit.
i've also had to compensate my idle to around 1000-1100 because the engine idles so poorly below that, and power off idle at 950rpm is horrible.  the engine nearly stalls at that rpm.  most likely due to bad injector(s)
with new nozzles & breaking pressure set correctly, the properly metered fuel entering the pre-chamber at exactly the right moment will burn more efficiently.  alter the breaking pressure, and you alter your timing...  i'm pumped to install the gtd nozzled injectors!!!
Reply #9January 18, 2007, 09:49:31 pm
zagarus
  • 619
« Reply #9 on: January 18, 2007, 09:49:31 pm »
do it its a nice thought to know your car is burning fuel more efficiently.  It pay itself back in no time!
Reply #10January 18, 2007, 09:52:59 pm
anarchyx34
« Reply #10 on: January 18, 2007, 09:52:59 pm »
Quote from: jtanguay
I know, I know. I need to do them. I'm just worried about that crack in one of my injector bosses. I cant afford to have any downtime with this car right now as my other car needs a good amount of work and cant be trusted for daily use. Nor can I afford a new cyl.head and whatever else is needed to replace it. There's a good chance I might be able to get the new injectors in without any problems, but I generally haven't had the best of luck when it comes to working on this car.
How much should I pay for a set of new/rebuilt injectors? GTD or otherwise?
Reply #11January 19, 2007, 04:20:55 am
« Reply #11 on: January 19, 2007, 04:20:55 am »
well for rebuilt from bosch on autopartsonlinecanada i saw them for around $56 a piece with a $20 core.  i bought 4 injectors from addautomotive for $40 and with that he shipped them directly to smog for me... pretty cool... then smog installed new nozzles and set the pressure for 160 bar i believe.. $125.  so i got a better nozzle than stock and for cheaper than rebuilt by bosch... but the bosch ones look so nice and shiney!!!  :lol:
as for removing them, i'm going to be spraying lots of penetrating lube around the injectors.  thing to remember is that aluminum likes to play when its warm... not when its cold.  when you do decide to do it, make sure the engine is good and hot.  it is also recommended that any force applied be toward the engine and not pulling away.  you will also need to work the injector back and forth (when doing this dont forget to apply pressure toward the engine.. never pull away from the engine even though it might be a little faster..)
i will report back here to how easy/hard it was once i get mine swapped!
