Author Topic: pics of garret T2 and how to up the boost?  (Read 3624 times)
January 10, 2007, 03:30:37 am
carrizog60
  • 978
« on: January 10, 2007, 03:30:37 am »
a friend of mine got a passat swap to his golf D and now wants to add just a little more fuel and boost.
does anybody has a pic of this turbo/wastegate and if it is possible to increase the boost manually like kkk24?
thanks
Portugal
Reply #1January 10, 2007, 07:40:14 pm
HP
  • 225
« Reply #1 on: January 10, 2007, 07:40:14 pm »
 :wink:
Reply #2January 11, 2007, 03:59:27 am
carrizog60
  • 978
« Reply #2 on: January 11, 2007, 03:59:27 am »
how can i adjuste the boost on that?
it seems that as a lever of some kind in the back of the WG...
lets see if someone has done it before...
thanks helio for the pic 8)
Portugal
Reply #3January 11, 2007, 04:18:57 am
Benjamin
  • 485
« Reply #3 on: January 11, 2007, 04:18:57 am »
some wastegates are adjustable, look at the above picture, you see the "screw".
you better take a manual boost controller, you will see the boost come up quicker (and sooner i thought).
i drove without wastegate (the wastegate was not connected but it was on), i controlled the boost with feul quantity, but i think my turbo was running the last miles also  :wink:  (with disconnected wastegaate you also will see less lag)
Greetz, Benjamin
Must make +250hp
Reply #4January 11, 2007, 05:13:41 am
carrizog60
  • 978
« Reply #4 on: January 11, 2007, 05:13:41 am »
that is for a friend and is only to run a little more boost(15psi at the most) and fuel.he´s not going to adjust it often...
Portugal
Reply #5January 11, 2007, 10:18:17 am
Benjamin
  • 485
« Reply #5 on: January 11, 2007, 10:18:17 am »
Quote from: carrizog60
i suggest to buy a manual boost controller anyway, you will get more power in low rpm becouse of less lag  :wink:  boost controllers are so cheap
Greetz, Benjamin
Must make +250hp
Reply #6January 11, 2007, 03:20:40 pm
carrizog60
  • 978
« Reply #6 on: January 11, 2007, 03:20:40 pm »
that is not for me...
in my friends opinion the engine was left stock... :roll:
Portugal
