How much power with your 1.9 TD ??
Topic: How much power with your 1.9 TD ?? (Read 9181 times)
January 20, 2007, 03:28:14 pm
JetPo
January 20, 2007, 03:28:14 pm »
Hi everybody. I'm will probably swap a 1.9 TD in my mk2 jetta (1.6 TD). And i wanted to know how much power you can get with a very godd setup. As anybody put is car on a Dyno. If so, can i know what results you got, and with what modification.
Thank You
Alex
January 21, 2007, 05:52:03 am
bert
January 21, 2007, 05:52:03 am »
I have put a 1.9 TD AAZ into a mk1 golf,fitted the 1.6 TD garrett T3 turbo,altered the aneroid pin,used a 2.5 inch stainless exhaust with 1 silencer at the rear,AND IT ABSOLUTLEY FLIES,im welll happy with it,no smoke under full load,and its currently got no intercooler,im having it dyno tested in the spring when i dig it out to play,will post results.
Bert
January 21, 2007, 07:54:28 am
mdonau
January 21, 2007, 07:54:28 am »
hi,
Quote from: bert
planning quite the same setup in my audi 80, at which rpm does the turbo make "usable" boost?
michael
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
January 21, 2007, 08:22:15 am
1.9blues
January 21, 2007, 08:22:15 am »
i was planning on upgrading to a t3 also... what is the spec for the T3 turbo?
January 21, 2007, 08:39:01 am
bert
January 21, 2007, 08:39:01 am »
Hi,the boost comes in at about 2400 rpm,and its like a different car,the acceleration in 5th is amazing,its as strong in 3rd,im really impressed with it,im hoping an intercooler will help more,TBA.............
Bert
January 21, 2007, 10:44:48 am
con
January 21, 2007, 10:44:48 am »
Bert that car sounds kickass, any chance of a few pictures?
January 21, 2007, 11:16:40 am
bert
January 21, 2007, 11:16:40 am »
pics a pleasure.
heres the T3 trial fit to see what it looks like.
Bert
January 21, 2007, 12:20:49 pm
JetPo
January 21, 2007, 12:20:49 pm »
Thanks guys, (Bert) Let me know when you get those numbers
January 21, 2007, 12:47:36 pm
bert
January 21, 2007, 12:47:36 pm »
Will do :twisted:
Bert
January 21, 2007, 12:52:04 pm
zagarus
January 21, 2007, 12:52:04 pm »
that turbo is gigantonormous!! much lag?
January 21, 2007, 02:03:29 pm
bert
January 21, 2007, 02:03:29 pm »
its a garrett T3 off a mk2 golf 1.6 TD it boosts about 2400 rpm,and its good fun :wink:
Bert
Reply #11
January 21, 2007, 02:13:07 pm
SMOKEYDUB
Reply #11 on:
January 21, 2007, 02:13:07 pm »
clean rabbit man. Nice project :wink:
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #12
January 21, 2007, 02:18:10 pm
bert
Reply #12 on:
January 21, 2007, 02:18:10 pm »
:wink: cheers
Bert
Reply #13
January 21, 2007, 03:55:08 pm
zagarus
Reply #13 on:
January 21, 2007, 03:55:08 pm »
thats the same turbo i have!!?!?! i knw mines a garrett, but is its a T3? what was stock on a 1.6LTD?
Reply #14
January 21, 2007, 04:07:42 pm
SMOKEYDUB
Reply #14 on:
January 21, 2007, 04:07:42 pm »
that is the identical that came on the older mk2 vw later on for some reason the changed to k24.yes your is a T3
(courtesy of GILES)
