Intercooler ideas and pictures
Topic: Intercooler ideas and pictures (Read 15267 times)
May 28, 2006, 03:43:48 pm
sethyboy85
May 28, 2006, 03:43:48 pm »
I need some ideas on Intercooling my A2, I would rather install a Intercooler than worry about refilling the water jug for a water injection system. I just was wondering if anybody had a IC installed and woulnd't mind posting a picture.
thanks.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
May 28, 2006, 03:55:21 pm
Benjamin
May 28, 2006, 03:55:21 pm »
post youre engine bay pls.
If you can make it youreself, you maybe can use a water to air IC.
Anyway, if you use waterinjection, i still would use a w/aIC ore a FMIC becouse you got less turbolag.
Greetz, Benjamin
Must make +250hp
May 29, 2006, 11:13:04 am
SMOKEYDUB
May 29, 2006, 11:13:04 am »
here is my intercooler setup it works excellent.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
May 29, 2006, 12:00:42 pm
HP
May 29, 2006, 12:00:42 pm »
So many curves, man!
Probably it had to be that way, huh
Golf II GTD --
http://www.clubegolfpt.com/forum/viewtopic.php?t=2488
May 29, 2006, 01:11:08 pm
SMOKEYDUB
May 29, 2006, 01:11:08 pm »
ya especially because its 2.5 inch piping.but i dont think the curves would effect it enough at all to worry about it.
(courtesy of GILES)
May 29, 2006, 08:03:15 pm
sethyboy85
May 29, 2006, 08:03:15 pm »
what kind of IC is that? still have AC?
I am trying to retain AC if at all possible.
May 30, 2006, 03:03:54 pm
SMOKEYDUB
May 30, 2006, 03:03:54 pm »
its a 2003 saab 95 intercooler and i dont have ac and if i did it would come out it would never fit in my case.
(courtesy of GILES)
May 30, 2006, 09:34:20 pm
LeeG
May 30, 2006, 09:34:20 pm »
is your radiator flipped upside down and mounted lower? no radiator fan anymore?
'97 Passat TDI
May 31, 2006, 07:18:36 am
Hey
May 31, 2006, 07:18:36 am »
1.8T IC (mk4) in a 1.9td 1995
here are some (big) pictures
http://img.photobucket.com/albums/v319/bareil76/IMG_0386.jpg
We can see on the next pictures that the exit is going toward the front of the car instead of the back (as it would do if the IC was on the passenger side) This is no big deal since, as a gift, we did'nt need to cut the protector under the car.
http://img.photobucket.com/albums/v319/bareil76/IMG_0388.jpg
we cut a small piece of metal just to avoid contact between the intercooler and the bumper.
http://img.photobucket.com/albums/v319/bareil76/IMG_0389.jpg
http://img.photobucket.com/albums/v319/bareil76/IMG_0391.jpg
http://img.photobucket.com/albums/v319/bareil76/IMG_0395.jpg
http://img.photobucket.com/albums/v319/bareil76/IMG_0392.jpg
May 31, 2006, 10:08:40 am
DieselMonkey
Mk3 T-IDi
May 31, 2006, 10:08:40 am »
Heres my setup.
[/img]
May 31, 2006, 12:56:32 pm
Staley
May 31, 2006, 12:56:32 pm »
NOW that is CLEAN!
nice Job
Houston's APR Distributor
www.bartuning.com
Reply #11
May 31, 2006, 05:52:22 pm
SMOKEYDUB
Reply #11 on:
May 31, 2006, 05:52:22 pm »
beautiful job. Im not sure what the rad is from passat maybe? and the rad fan i cant find one small enough still on the look out. i had to modify the lower part of the rad support alot and make up brackets for the ic and the rad to sit on. I thought it was too much work but in the end i found out it works awesome so im happy. still not completly done the project i just needed to drive something to work. So now im still driving with an open 2.5 inch down pipe :lol: its to loud but it works im getting the exhaust on it tomorrow. 2.5 inch straight pipe.
(courtesy of GILES)
Reply #12
May 31, 2006, 06:04:06 pm
sethyboy85
Reply #12 on:
May 31, 2006, 06:04:06 pm »
hey I have the turbo lined up 1 1/2" above the factory toilet bowl and that is it.
engine bay is starting to get dirty after 1,500 miles but I am waiting on my DP from passenger performance and then I am getting a 2.5" exhaust fabbed up either by me or a local guy who does good work.
oh yeah keep the pictures coming... I am thinking I will have to go with a smaller radiator and am trying to figure out if I can use a volvo IC (one of many various IC I have) and then make something so all the air is forced through the AC/IC/rad and block off all other air passage ways in the engine bay, put a slim high CFM fan on and set it on a manual thermostat to kick on whenever the coolant hits a certain temperature.
Reply #13
May 31, 2006, 06:05:44 pm
SMOKEYDUB
Reply #13 on:
May 31, 2006, 06:05:44 pm »
(courtesy of GILES)
Reply #14
May 31, 2006, 10:09:28 pm
Staley
Reply #14 on:
May 31, 2006, 10:09:28 pm »
Just change your moniter to 1280x1024 and the pictures will get smaller
www.bartuning.com
