Author Topic: clutch is slipping at 20psi need a new clutch please help  (Read 2603 times)
January 21, 2007, 09:07:49 pm
bustedfoxwagen
  • 31
    • http://www.wagenwerks.net
« on: January 21, 2007, 09:07:49 pm »
ok put in my gtd nozels, and turned up the boost and fuel, now the clutch starts to slip about 3000rpm (20psi) and then goes to 23psi and the tach shoots up then the clutch grabs again and boost and rpm's go down
anyways i need a decent "performance" clutch i guess, thanks guys, im was told on vortex that some one up here has a very nice clutch kit for 160. good pp and a 4 or 6 puck clutch
92 eco diesel jetta
Reply #1January 22, 2007, 04:43:16 am
« Reply #1 on: January 22, 2007, 04:43:16 am »
http://vwdiesel.net/phpBB/viewtopic.php?t=4961
give the vendors section a browse, there is lots of good stuff in there
Reply #2January 22, 2007, 11:57:08 am
veeman
  • 421
« Reply #2 on: January 22, 2007, 11:57:08 am »
FWIW, on my "other" rabbit (gasser GTI autox car), I went with a six-puck clutch disk sourced from BSI Racing.  When I got it, it was in a Kennedy Engineering Products box, so I suppose they're the ones making them.
The disk I have is some sort of kelated copper ceramic material that's really tough.  It took some getting used to / bedding in, but it's been great.  It's definitely more on/off than the stock setup, but combined with a 16V pressure plate, I haven't had any problems with it in 5 years of hard race abuse.
I went with the six-puck over the four puck because Stu at BSI said that the 4 puck was less brutal / easier to drive for street use than the 4 puck.  Not sure... I've never had one.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #3January 22, 2007, 08:46:32 pm
bustedfoxwagen
  • 31
« Reply #3 on: January 22, 2007, 08:46:32 pm »
thanks guys im looking in there now
92 eco diesel jetta
