View full version: IDI Engine
  1. HELP !! AAZ WONT REV ?!?!?!?
  2. WTF timing!
  3. TD injection pump into an N/A with N/A injectors
  4. Building a set of 155 injectors with a set of 130s
  5. biodiesel question
  6. resurfacing AAZ head
  7. AAZ crankshaft tolerances
  8. Oil Filter Question
  9. My IP bracket cracked in half
  10. Here is the PDF: ProTraining: Four Cylinder DIESEL 77-83
  11. vacuum line behind glove box
  12. has anybody seen this on a rabbit?
  13. IP rotor and head size
  14. For those with the upshift ligh thingymabob
  15. 1.6TD fitment in a mk1
  16. 1.9 AAZ bling ??
  17. 91 eco ticking noise
  18. Air in fuel Lines
  19. Bought an Eco, need to get it running and on the trailer.
  20. power vs. engine/gearbox?
  21. help diagnose this issue (video inside)
  22. What are these IP parts? AAZ
  23. eco ip/ td ip needed
  24. EGT gauge (got a good source)?
  25. timing woes/ need help
  26. K14 Turbo wastegate adjustment
  27. ANOTHER! AAZ broken timing belt!!!!!!!!
  28. lowering compression
  29. Product Review and install: VDO Cockpit 0-30psi boost gauge
  30. Increasing blowby
  31. Good Exhaust Shop
  32. Timing belt condition
  33. 1.9 head?
  34. too much boost???
  35. Clutch question
  36. 1.6 pump on a 1.5?
  37. back fire exhaust popping
  38. glow plug relay repair
  39. spearco turbo fuel aneroid(LDA) need installation directions
  40. Anyone see a problem with this? AAZ to Vanagon.
  41. Looking for a shop to pop test in lower mainland
  42. chev tracker adapter kit for vw td engine
  43. Copious amounts of white smoke
  44. Mercedes injectors in a 1.6td?
  45. I need an AAZ manual
  46. 82 bunny question
  47. Gasket between manifold and turbo.
  48. Catastrophic failure?
  49. Why Go Synthetic?
  50. dipstick tube removal ?
