Author Topic: IP rotor and head size  (Read 1992 times)
October 12, 2007, 10:05:02 am
rabfan
  • 28
« on: October 12, 2007, 10:05:02 am »
I'm sure I'll get slammed with "use the search" but that proved to be a little fruitless.
I am rebuilding my injector pump.
I have an 83 1.6 turbo diesel IP and I'm wondering if the 10mm rotor and head unit will fit on it. I recall reading on here somewhere that this is an upgrade.
WHat advantages will this give over the stock 9mm rotor and head unit?
Thanks,
RJ
Reply #1October 12, 2007, 10:13:36 am
« Reply #1 on: October 12, 2007, 10:13:36 am »
more fuel flow.  in conjunction with bigger injections, you can expect more power, and even economy in some cases.
Reply #2October 12, 2007, 04:24:00 pm
rabfan
  • 28
« Reply #2 on: October 12, 2007, 04:24:00 pm »
Thank you for your reply. I have also ordered the 1.9 cam plate for the pump.
the plan is to remain 1.6 for displacement. hopefully the pump will not be overkill.
