Author Topic: 91 eco ticking noise  (Read 2721 times)
October 04, 2007, 07:29:55 pm
trent77
  • 217
« on: October 04, 2007, 07:29:55 pm »
After my jetta warms up I get a ticking noise around the valve cover area. I have a hydraulic head (not sure if they all do in these years) It sounds like a loose rocker, but with no adjustment that seems strange. Also I would think that would be worse when cold, not warm. It's my first older vw diesel in awhile, but this doesn't sound normal. Any help is appreciated.
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1October 04, 2007, 07:48:14 pm
mk2diesel
  • 60
« Reply #1 on: October 04, 2007, 07:48:14 pm »
sounds like lifters ( oil thins out when cold and can't fill the wear gaps in the lifters)   just try a thicker oil  and see if the problem lessens ...
if it does, consider changing the cam followers (lifters)
Reply #2October 10, 2007, 05:13:09 pm
« Reply #2 on: October 10, 2007, 05:13:09 pm »
how long has it been since you changed your oil? I heard that same sound in a '90 1.6L NA, when I'd rev it the ticking would go away 'till it idled down again for a few seconds.
Reply #3October 10, 2007, 07:55:36 pm
trent77
  • 217
« Reply #3 on: October 10, 2007, 07:55:36 pm »
Just changed oil. 15/40 delvac. the ticking noise is continuous at all rpms.
77 westfalia
06 GMC Duramax
Reply #4October 11, 2007, 02:22:20 am
Ziptar
  • 565
« Reply #4 on: October 11, 2007, 02:22:20 am »
Seafoam!
It cured a noisy lifter in my friends 8V Gas Jetta years back. I have a can in the garage that I am going to use and see if I can cure a noisy lifter in the Audi 200 as soon as I get time.
