91 eco ticking noise
Topic: 91 eco ticking noise (Read 2722 times)
October 04, 2007, 07:29:55 pm
trent77
October 04, 2007, 07:29:55 pm »
After my jetta warms up I get a ticking noise around the valve cover area. I have a hydraulic head (not sure if they all do in these years) It sounds like a loose rocker, but with no adjustment that seems strange. Also I would think that would be worse when cold, not warm. It's my first older vw diesel in awhile, but this doesn't sound normal. Any help is appreciated.
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
October 04, 2007, 07:48:14 pm
mk2diesel
October 04, 2007, 07:48:14 pm »
sounds like lifters ( oil thins out when cold and can't fill the wear gaps in the lifters) just try a thicker oil and see if the problem lessens ...
if it does, consider changing the cam followers (lifters)
October 10, 2007, 05:13:09 pm
rabbitman
October 10, 2007, 05:13:09 pm »
how long has it been since you changed your oil? I heard that same sound in a '90 1.6L NA, when I'd rev it the ticking would go away 'till it idled down again for a few seconds.
October 10, 2007, 07:55:36 pm
trent77
October 10, 2007, 07:55:36 pm »
Just changed oil. 15/40 delvac. the ticking noise is continuous at all rpms.
77 westfalia
06 GMC Duramax
October 11, 2007, 02:22:20 am
Ziptar
October 11, 2007, 02:22:20 am »
Seafoam
It cured a noisy lifter in my friends 8V Gas Jetta years back. I have a can in the garage that I am going to use and see if I can cure a noisy lifter in the Audi 200 as soon as I get time.
