View full version: IDI Engine
  1. EGT temps .. muffler? - EDIT, Have you checked your muffler lately?
  2. Filter head banjo size on Mk1?
  3. US To CE2 Turn Stalk Wring
  4. Aaz coolant outlet alternatives
  5. Crank Bolt Tango....Getting sick of this dance.
  6. Aaz timing belt sliding on pulley
  7. Opinions - Corrado VR6 throttle cable for my bizarro mitsubishi linkage?
  8. 1.6td setup
  9. My new toy/project
  10. AAZ pump question
  11. Instantaneous MPG Meter????
  12. Come On Now, Let's Dump That Old Fashioned Mirror !!!!
  13. Myth dispelled?
  14. New goodies
  15. Cooling System Questions
  16. TD04-13g ? Help with Compressor maps
  17. Why Carry All of That Diesel Around???
  18. power steering belt adjustment and squeal
  19. freshening up a 1.9
  20. Time to start assembling 1.5 TD / 1.9L Franken Diesel.
  21. VW Oil Sender vs VDO Gauge Sender Threads
  22. AAZ vanagon project thread
  23. Turbo adapters
  24. 1.5/1.6 hybrid build
  25. Oil pressure jumping around at higher RPM's - add a windage tray?
  26. aaz solid lifter conversion
  27. What is that one wire?
  28. 1.6 TD & 1.9 AAZ Intake Gasket ( Neck )
  29. Bosch VE Pump.....Break In????
  30. DIY Anti-Rattle Clips for MK2 1991 Jetta??
  31. Parts / manuals for 1Y ???
  32. Resetting Used Odometer MK2 Cluster to Show True Miles
  33. Running Biodiesel in the Bosch VE Pump
  34. DIFFERENCES BETWEEN T2, T3, K14 & K24 TURBOS
  35. Effectiveness of a Front Air Dam????
  36. Brake Fluid/Bleeding Questions??
  37. Baffling a pan for land-speed vehicle.
  38. How to Prime the Injection Pump??
  39. Holset Q
  40. Injector pump sequence
  41. trans problems multiplying...
  42. Using a Spark Plug Connector for the Glow Plugs????
  43. I need a coolant line plug
  44. black diesel
  45. diesel flywheel timing marks
  46. replacing injection pump drive shaft bearings
  47. Engine Oil Pressure Gauge Range....Questions???
  48. MK2 Front Shock Installation ????
  49. turbo reading(schwitzer s100)
  50. Injection pump pressure regulator spring
