View full version: IDI Engine
  1. A question about rod bushings.
  2. Techtonic downpipe?
  3. Steel Replacement Brake line
  4. OH Shoot, pulling vibration dampener...
  5. Parts in Canada
  6. Can't isolate wobble on vibration dampener on AAZ engine. With video!
  7. Adding a turbo to an NA
  8. AAZ clutches
  9. Porting IDI heads - please quantify
  10. Can someone point me to a online place i can order a 1.9L AAZ headgasket??
  11. Which tranny with modified AAZ?
  12. breather hose
  13. AAZ Pre-Comb. Chanmers in a 1.6l na?
  14. TDI pump kit O-Rings
  15. Rotor head O ring size - GTD pump.
  16. Merry Christmas diesel dudes.
  17. Head gasket torque
  18. Snapped hose off rotary type vacuum pump, do I have to buy a new pump?
  19. Stainless manifold?
  20. coolant around head gasket (PIC ADDED)
  21. AAZ Connecting Rod Torque ?
  22. Nitrous question
  23. AAZ valves, where do you get them?
  24. What is going on here???? (turbo pump on an NA??)
  25. tell tale signs of AAZ condition
  26. 1.6 turbo diesel H-beam rods
  27. Where do you get parts for your AAZ?
  28. question about the cold start lever
  29. AAZ valve and lifter question..
  30. Did I screw up?
  31. ajm 150 intake manifold or pd 150 intake manifold?
  32. Complete 1.6TD drivetrain drop on MKII doable ?
  33. 1.9 N/A & 1.9 AAZ BREATHER HOSE ( NEW PRODUCTION )028-103-493 Q
  34. New Production 191121101Q Upper Radiator Coolant Hose ( Silicone )
  35. Injector Question
  36. Best exhaust line for 1.6TD ?
  37. My build up of the Un-naturally aspirated 81.
  38. bigger exhaust for 89 Jetta 1.6 NA
  39. Radiator types?
  40. i'm going to build a how to 1.6na t 1.6TD thread. need advice
  41. Gasoline effect on performance?
  42. 11mm 1.6 TURBO block?!?!
  43. Injector pump head O-ring source?
  44. 1.9TD project?
  45. T2 turbo
  46. Can anyone find it?/Build it?
  47. T-3 Wastegate valve seat cracked (Fixable?)
  48. Custom Intercooler's ( Based on 675 MM Radiator )
  49. Valve cover beather hose
  50. head gasket question
