Author Topic: Injector pump head O-ring source?  (Read 2210 times)
December 13, 2010, 07:37:38 pm
Jory
  • 55
« on: December 13, 2010, 07:37:38 pm »
My pump has started leaking from the pump head, but nowhere else at the moment. I'd normally pull the pump and completely reseal it, but I plan to drop a 1.6TD in the Golf before long so I'd like to keep the work on the current pump to a minimum.
Is there a place where I can buy just the o-ring separately?
thanks,
Jory
Reply #1December 13, 2010, 07:39:48 pm
Jory
  • 55
Re: Injector pump head O-ring source?
« Reply #1 on: December 13, 2010, 07:39:48 pm »
damn, didn't realize that was my first post on this board. guess I've been lurking.
hi everyone ;D
Reply #2December 13, 2010, 07:55:58 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #2 on: December 13, 2010, 07:55:58 pm »
Oh Hi! And welcome..
I usually get mine from Seattle Injector. They can sell whole kits or just parts. here is the contact info:
1410 Airport Way South
Seattle, WA 98134-1613
(206) 623-1135
Reply #3December 13, 2010, 10:02:45 pm
  • 2932
« Reply #3 on: December 13, 2010, 10:02:45 pm »
A DGK-126 seal set will have that o-ring,.. and 6 nice screw-on injector caps, etc.
Any bosch service center can find the part number and get you just that o-ring.
 Theree is a bosch service center locator on the internet.
Reply #4December 14, 2010, 01:11:29 pm
damac
  • 531
« Reply #4 on: December 14, 2010, 01:11:29 pm »
I get my kits from ebay with the front seal, cheaper than my local bosch dealer.
But I did that seal on my old 85 jetta turbo diesel that I picked up months ago, because it sprung a leak there after my first drive home!  I did that seal and then it started coming out of the cold start lever!
So then I pulled the pump off and did as many of the seals as I could without complete teardown because I didn't know any better.  Finally I put a new seal on the mainshaft but after I took the old rock hard seal off I noticed major shaft wear :(  When I went to start the car up fuel spit out all over my timing belt.  I already knew I couldn't use the pump like that after reading on the forums but I wasn't expecting that :(
Anyways maybe its coincidence that mine sprung a leak elsewhere but be prepared?
1985 turbo diesel jetta
