Author Topic: 1.9TD project?  (Read 10519 times)
December 05, 2010, 05:59:14 pm
xxkoadyxx
  • 179
1.9TD project?
« on: December 05, 2010, 05:59:14 pm »
I picked up another 1.9td and trans today.. This 1.9 has a ko3 turbo on it.. what should i do and get for this engine.. im looking to get more hp ouut of it.. any suggestions on what needs to be done? thanks. im looking for 150ish hp :P
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1December 05, 2010, 10:18:34 pm
GEE-BEE
  • 1604
Re: 1.9TD project?
« Reply #1 on: December 05, 2010, 10:18:34 pm »
Giles pump, intercooler is a must
Go to a Hybrid K03 or VNT or T3turbo will require a different manifold and will change to a different downpipe
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2December 06, 2010, 12:47:55 am
Alcaid
  • 549
Re: 1.9TD project?
« Reply #2 on: December 06, 2010, 12:47:55 am »
Wrong, the '93 Golf should have the square 4-bolt flange on the downpipe, same as the T3. They didn't change downpipe flange until '94.
Don't remember if it has the triangle or the trapezoidal exhaust manifold flange but if it's the triangle one, a manifold from 1.6TD would make that turbo plug right in there, maybe some small changes to the oil feed/return and hosework.
'10 VW Passat 1.6TDI Highline
Reply #3December 06, 2010, 06:31:24 am
xxkoadyxx
  • 179
Re: 1.9TD project?
« Reply #3 on: December 06, 2010, 06:31:24 am »
what is a hybrid KO3?
Reply #4December 06, 2010, 07:49:08 am
GEE-BEE
  • 1604
Re: 1.9TD project?
« Reply #4 on: December 06, 2010, 07:49:08 am »
KO4 hotside with a K03 coldside
manifolds are different on T2/T3/K14 series versus K03 turbo
The Intake boot from Filter( snorkel) and turbo to intake manifold  is different also
Ask me how I know ?
or you can listen to Numb's nut's above...
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #5December 06, 2010, 02:18:24 pm
xxkoadyxx
  • 179
Re: 1.9TD project?
« Reply #5 on: December 06, 2010, 02:18:24 pm »
Ask me how I know ?
GB
the engine in my car right now is a 1.9td also but it has the k14.. inlet/airfilter side is alot bigger then the ko3, but i cant adjust the boost on the k14..which would be better?
Reply #6December 06, 2010, 03:08:23 pm
Thezorn
  • 381
Re: 1.9TD project?
« Reply #6 on: December 06, 2010, 03:08:23 pm »
you sure can, all you need is a manuall boost controller in the line that goes between the turbo to the wategate. I have mine regualted to 15 psi and it works great.
Compounded 93 AAZ
Reply #7December 06, 2010, 03:17:28 pm
xxkoadyxx
  • 179
Re: 1.9TD project?
« Reply #7 on: December 06, 2010, 03:17:28 pm »
there is no line.. only a metal line. would that be it? looks like an oil line to me.. heres pic.....
« Last Edit: December 06, 2010, 03:27:39 pm by xxkoadyxx »
Reply #8December 06, 2010, 03:33:45 pm
Re: 1.9TD project?
« Reply #8 on: December 06, 2010, 03:33:45 pm »
That's the one.   ;)
Reply #9December 06, 2010, 03:44:51 pm
xxkoadyxx
  • 179
Re: 1.9TD project?
« Reply #9 on: December 06, 2010, 03:44:51 pm »
question, whats the purpose of a boost controller? stock the flow of air going through lines? if so cant i just sqweeze the line? lol
Reply #10December 06, 2010, 03:50:51 pm
Re: 1.9TD project?
« Reply #10 on: December 06, 2010, 03:50:51 pm »
That steel line is feeding back boost to the wastegate... allowing the turbo to regulate itself to the set boost level. A boost controller "tricks" the wastegate by showing it less than the full output... so the wastegate ups the boost accordingly.
Pinching the line would merely slow down the flow and thus the response time of the wastegate, but would have very little effect on the setpoint, since the wastegate would still see the same pressure.
Reply #11December 06, 2010, 04:47:27 pm
xxkoadyxx
  • 179
Re: 1.9TD project?
« Reply #11 on: December 06, 2010, 04:47:27 pm »
alright so that is the line.hmm ok so ill need to cut it,flare it,then add hose to it? boost gauge is a must.. whats max i should stay from with stock block.. only untill i get my other built..
Reply #12December 06, 2010, 08:55:25 pm
Re: 1.9TD project?
« Reply #12 on: December 06, 2010, 08:55:25 pm »
Nylon Home Depot tubing slipped over the cut off ends of the metal line... I ended up putting a zip tie around each of them as a hose clamp eventually.  Humidifier bleeder valve connected to the 'T' to bleed off pressure and hide it from the wastegate.
$5...  I keep it at 15, but have ended up a bit higher a couple of times by "accident"... It seems generally speaking 15 PSI is the most you should do without an intercooler - after that you are heating up the air so much compressing it that you are negating the benefits of higher pressure.
My boost gauge is from Princess Auto and cost almost nothing.  Any pressure gauge will work!  I tee'd mine in to the air line to my LDA.
« Last Edit: December 06, 2010, 08:59:53 pm by vanbcguy »
Reply #13December 06, 2010, 10:47:33 pm
Alcaid
  • 549
Re: 1.9TD project?
« Reply #13 on: December 06, 2010, 10:47:33 pm »
NXT Boost Controller is 20$ on Ebay without the ghetto DIY look ;)
You can eliminate the metal line all together by using banjo/barb fittings.
Reply #14December 07, 2010, 10:16:07 am
Re: 1.9TD project?
« Reply #14 on: December 07, 2010, 10:16:07 am »
Ask me how I know ?
GB
most of the time its a K04 cold side (more flow) and a K03 hot side (quick spool) that make up a K03 hybrid.. they do come both ways (obviously, as Mr. GB is running one of them) but it is said that the 04 cold side will make better results.
