Author Topic: Radiator types?  (Read 6702 times)
August 21, 2010, 07:39:36 am
wil892
  • 216
Radiator types?
« on: August 21, 2010, 07:39:36 am »
Hi
My GTD has its original radiator, so being almost 20 years old I think it could be the cause of my slightly warmer temperatures when going up hill. It currently runs the VW G12++ antifreeze and all is clear but I think that over 20 years the efficiency must have decreased.
Anyway, having had bad experiences with cheap radiators I'm looking for a good quality one. I've noticed that the original radiator has the flat cores, like this Nissens one.
http://www.mjmautohaus.com/catalog/product_info.php?cPath=2_6_14_50_101_1362&info=Nissens_191121253A_Radiator_With_A/C&products_id=2221
but looking on ebay all the radiators have the thick cylindrical cores running through the middle.
The original radiator looks like it would have a better efficiency than these ones, so what make radiator can I buy that will give me the flat cores and quality i'm looking for.
Obviousely I would buy from MJM but my car doesnt have AC and I'm in the UK.
Thanks
Will
1991 Golf MK2 GTD
Reply #1August 21, 2010, 09:03:39 am
GEE-BEE
  • 1604
Re: Radiator types?
« Reply #1 on: August 21, 2010, 09:03:39 am »
A/C UNITS 575 MM LONG
SCIROCCO 16 V 675 MM LONG
GERMANAUTOPART.COM
AZAUTOHAUS.COM
16V SCIROCCO 1988 87.00 NEW ( 675 MM )
My next install project MK
I will duplicate the 16 v a/c radiator hoses also...
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2August 22, 2010, 06:18:58 pm
Quantum TD
  • 1195
Re: Radiator types?
« Reply #2 on: August 22, 2010, 06:18:58 pm »
GERMANAUTOPART.COM
AZAUTOHAUS.COM
The 16V Scirocco is the EXACT same radiator used on all MK2 diesels with AC. Absolutely no difference whatsoever. Installing one on a MK1 involves some modifications to say the least.
Reply #3August 22, 2010, 08:07:55 pm
GEE-BEE
  • 1604
Re: Radiator types?
« Reply #3 on: August 22, 2010, 08:07:55 pm »
16v scirocco with a/c has a angled out upper outlet and the hose has a t line to resv tank
This hose upper is 95.10 new
Lower 533121051a 16V lower
Non a/c 675 mm have a overflow nipple on the radiator, uses 7.5 mm Coolant hose from radiator to overflow bottle
upper hose 191121101AB 15.50
Upper radiator hose with a/c Jetta 1991 diesel
191121101AK upper with t coolant  40.26
191121051P lower radiator 7.87 , fit's 16v also
Both models will be in put in silicone 5 ply in the future
GB
« Last Edit: August 22, 2010, 08:27:35 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #4August 23, 2010, 10:13:53 am
Baron VonZeppelin
Re: Radiator types?
« Reply #4 on: August 23, 2010, 10:13:53 am »
I don't think there is any way you could install the 675mm radiator into an Mk1 - with all stock stuff.
But open to correction.
It might be because i have A/C and the arrangement puts the alternator out farther towards the radiator ? both mine have A/C so its all i got to go by.
The 575mm unit is all it can handle. Goes from alternator to driver headlight with very very little room left.
I got a Modine brand 575mm, i think that is what MJM offers also.
It was quality merchandise. A local Worldpac dealer matched MJM price of $125 out the door.
You could definitely drop the 575mm right into place on your Non-A/C car. The radiator support top rail has the provision for it.
And if there is room for a radiator to go past your alternator, you could do the 675mm probably also.
Reply #5August 23, 2010, 11:49:15 am
GEE-BEE
  • 1604
Re: Radiator types?
« Reply #5 on: August 23, 2010, 11:49:15 am »
I have a south african core support ,26.5 inches will work , I have room on both side for intercooler
575 MM Installed now
I will let you know in a few day's
No a/c,  plenty of room for 28 x 2.5 Intercooler
GB
« Last Edit: August 23, 2010, 01:05:58 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #6August 23, 2010, 01:25:19 pm
GEE-BEE
  • 1604
Re: Radiator Install / 675 mm
« Reply #6 on: August 23, 2010, 01:25:19 pm »
Hey Baron care to bet on this..... ?
I will have parts in a couple of day's
Going to pull the radiator fan support for powdercoating satin black, I will install a new fan....
waiting on some paint from Expresspaint.com
They do oem color matches in a can, removing battery bracket....
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #7August 23, 2010, 07:36:57 pm
Baron VonZeppelin
Re: Radiator types?
« Reply #7 on: August 23, 2010, 07:36:57 pm »
I'd bet on mine, but not on yours !  ;) lol
I think you already did the 675mm with South African front on the last Truck already.
I'm just curious if one were using all bone stock USA assembly line components - if they could handle the 675mm - on a Non A/C Mk1 car. All the Mk1's i have access to around here are factory A/C.
The A/C cars have no chance if still wearing a compressor/alt arrangement. And I'm amazed how folks get by with stock Mk1 non-A/C radiators - especially with a TD engine.
Those rads are tiny.
I'm using Mk2 shroud / 2spd fan / blade.
71c Thermostat
Been using 85c/93c fan switch because it was all i could get at that time - but haven't really liked how the gauge reads to me sometimes in some conditions.
Just got a 75c/82c fan switch in hand - should do the trick like i want. Let that fan run some for goodness sakes. Its why i put it in there anyway. I can get more fans !! It was hardly ever coming on.
Reply #8August 24, 2010, 08:23:23 pm
GEE-BEE
  • 1604
Re: Radiator types?
« Reply #8 on: August 24, 2010, 08:23:23 pm »
675 mm fit's, Iam just use the lh hole in the SF core support, drill and dimple a new hole
Waiting on hoses and rubber bumpers for pin mounts and those hard to find radiator supports
The nissen's radiator is much better, the mk1 shroud fit's this and the coolant temp is not on the side like my 575 mm MK1 type
GB
search 1991 jetta 1.6 for parts at AUTOHAUSAZ.COM
RUBBER BUMPERS 171121276D
RADIATOR SUPPORTS 191121265C  &  191121265B
Giles Pump OHC
MK1 JETTA DASH
Reply #9August 26, 2010, 06:57:47 pm
GEE-BEE
  • 1604
Re: Radiator types?
« Reply #9 on: August 26, 2010, 06:57:47 pm »
It fit with room to spare on both sides !
Iam waiting on the MKII shroud to come back from the powder coater and will install a new two speed fan
I purchased a new a/c alternator bracket and I want to move the alt above to give more room around the lower hose assy
GB
Want a pic ?
let me know at [email protected]
Giles Pump OHC
MK1 JETTA DASH
Reply #10December 14, 2010, 01:53:55 pm
Rabbit79
  • 197
    Burns, Oregon,USA
Re: Radiator types?
« Reply #10 on: December 14, 2010, 01:53:55 pm »
Does anyone know where they put the part number on a radiator? I've looked all over mine and can't see one.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #11December 14, 2010, 11:52:29 pm
GEE-BEE
  • 1604
Re: Radiator types?
« Reply #11 on: December 14, 2010, 11:52:29 pm »
Is it a 525 or 568 long
The 675 a/c have a angle top
675 non a/c have straight outlet
Iam using a 16 v lower  a/c lower scirocco hose , since it make's a 90 degree bend down
Send me a pic
[email protected]
I have two a/c models 675, one 675 non a/c
and one 568 mk1
they are all metal type ( Beher) Brazil mfg'
Giles Pump OHC
MK1 JETTA DASH
Reply #12December 15, 2010, 08:58:09 am
BigVWman
  • 332
Re: Radiator types?
« Reply #12 on: December 15, 2010, 08:58:09 am »
I found the nissens one for GTD with air at FAP99.com for $84! If it helps anyone!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #13December 15, 2010, 10:44:08 am
Rabbit79
  • 197
    Burns, Oregon,USA
Re: Radiator types?
« Reply #13 on: December 15, 2010, 10:44:08 am »
[/img]
Core is 21 3/4". which according to my handy dandy cell phone converter calculator equates out to 552.45 mm. It also seems you don't see that 45 degree lower hose connection very often. I was just thinking if I could get an original part number I'd be better armed to do some cross referencing. Oh and it's a 79 Rabbit by the way...... I do believe that's the original radiator although I'm not 100% sure as I've only owned it since 96.
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #14December 15, 2010, 10:52:03 am
Re: Radiator types?
« Reply #14 on: December 15, 2010, 10:52:03 am »
straight lower outlet is more rare than the angled lower outlet.. try finding a hose for the straight outlet!
or maybe its the other way around.. but i swear its harder to get the straight connection radiators and hoses..
