Author Topic: Best exhaust line for 1.6TD ?  (Read 3676 times)
December 14, 2010, 06:53:46 pm
Laurentian
« on: December 14, 2010, 06:53:46 pm »
Picked un a near mint black '92 MKII Jetta 1.6TD, 375,000 km
rust proofed yearly no rust original paint
needs minor repairs, such as exhaust line and pump seals.
Can get a nice custom line done locally, should I go with 2 1/4" or 2 1/2" ?
Thinking free flowing muffler like a magnaflow ?
What about straight pine, I heard the turbo chops up a lot of the noise ?
Leaning to a mufflered line of course, just thought I'd ask ;D
Reply #1December 14, 2010, 08:40:37 pm
vanagonturbo
  • 639
    • Fine Tuning
Re: Best exhaust line for 1.6TD ?
« Reply #1 on: December 14, 2010, 08:40:37 pm »
2,5" straight pipe. If you care about your neighbors and people behind you, put a muffler on it..
Reply #2December 14, 2010, 09:51:36 pm
AudiVWguy
« Reply #2 on: December 14, 2010, 09:51:36 pm »
Are  you going to upgrade the down pipe at the same time as the rest of the exhaust?
Reply #3December 14, 2010, 11:16:30 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: December 14, 2010, 11:16:30 pm »
I thought that was a given?
Reply #4December 15, 2010, 07:16:59 pm
Laurentian
« Reply #4 on: December 15, 2010, 07:16:59 pm »
Yes of course on the downpipe, weld up the toilet bowl seat to
the new improved line. Yeah will go with a high flow muffler.
OK then 2.5 it is !
More later after the holidays with pics !
Hugh
Reply #5December 16, 2010, 07:18:38 am
« Reply #5 on: December 16, 2010, 07:18:38 am »
OK then 2.5 it is !
Hugh
thats not upgrading the downpipe. we are talking about the thing that comes out of the turbo, where the toilet bowl and c clips actually go. that cast iron downpipe is the limiting factor on the exhaust system. you can run 5" exhaust off the toilet bowl, and it will still not flow good like a 2.5" dp/full straight exhaust..
the downpipe is where you get most of your gains..
Reply #6December 16, 2010, 07:15:44 pm
Laurentian
« Reply #6 on: December 16, 2010, 07:15:44 pm »
Hmm, interesting.
I have access to a lathe, mill, grinder etc.
What can be done to enlarge and what kind of clamping method
recommended if I were to do this mod ?
What type steel or just go with cast iron welded in ?
My neighbour is a pro welder, I can machine and prep anything.
What dia. would you recommande after the K24 ?
Thanks, great info !
Reply #7December 16, 2010, 07:25:04 pm
« Reply #7 on: December 16, 2010, 07:25:04 pm »
I went 3" all the way back, 2.5 up to 3" would be good for a DP. This is what mine looks like and if you neighbor is a welder then you are in there like swimwear. Smoking Eddy has a thread on here of angles and stuff he just redid his like last week.
These guys have pre made 2.5 or 3 inch flanges to weld pipe to and summit racing/others have 180 degree mandrel bends in carbon and stainless steel. You would be looking at garrett T-3 stuff :D
http://weirtech.ca/catalog/index.php?cPath=13_17
« Last Edit: December 16, 2010, 08:11:50 pm by theman53 »
Reply #8December 16, 2010, 07:33:24 pm
Laurentian
« Reply #8 on: December 16, 2010, 07:33:24 pm »
Thanks, going home for the day.
Will research this over the weekend !
I'm running K24 on the MZ and K14 on the AAZ.
Would you mind emailing the photo to me ?
It does not come up here ..
gravure at msn dot com
Thanks !
Hugh
Reply #9December 16, 2010, 08:12:21 pm
« Reply #9 on: December 16, 2010, 08:12:21 pm »
missed a ]   should work now ;)
Reply #10December 16, 2010, 08:17:27 pm
Laurentian
« Reply #10 on: December 16, 2010, 08:17:27 pm »
Great, Thanks !
