Author Topic: tell tale signs of AAZ condition  (Read 2504 times)
December 21, 2010, 09:41:06 pm
erice1984
  • 263
« on: December 21, 2010, 09:41:06 pm »
If I were to buy an AAZ, are there any signs that I can look out for before purchasing, that would indicate bad things about the engine?
Like what is the deal with cracks between valves on the heads?
What is the deal with low mileage diesels in canada?
less miles = harder miles? more engine on/off cycles?    No idea what to think.
1980 Rabbit 1.9TD
Reply #1December 22, 2010, 08:59:42 am
GEE-BEE
  • 1604
Re: tell tale signs of AAZ condition
« Reply #1 on: December 22, 2010, 08:59:42 am »
There is a very clean one on Ebay with trans
Expensive thou
GB
You wont know until you pull the head
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2December 22, 2010, 11:49:16 am
BellCityDubber
  • 251
« Reply #2 on: December 22, 2010, 11:49:16 am »
hey.....
erice1984
I've seen some of your posts in the Vortex-ontario regional forums.
Usually with the lower milage diesels, they tend to have lots of on-off cycling as opposed to highway miles.
either way, it's not BAD or GOOD.... you'll definately want to check the condition of the head itself.
Reply #3December 22, 2010, 01:59:34 pm
  • 1739
« Reply #3 on: December 22, 2010, 01:59:34 pm »
Get a 22mm 12 point socket at turn the crank pulley back and forth to check for any play. However if it starts up easily cold and hot, idles nice right away. you're probably okay
