Author Topic: New Production 191121101Q Upper Radiator Coolant Hose ( Silicone )  (Read 2548 times)
November 20, 2010, 04:49:16 pm
GEE-BEE
  • 1604
Will fit MKI with 675 mm radiator, Standard hose on MKII 675 mm radiator
5 Ply Silicone , all color's
This fit's well with lower 16v a/c model hose 533121051A
or Non a/c lower hose 1911051 P ( no 45 degree down bend for a/c compressor )
My temp's have went down since these flow better
Want a pic ?
[email protected]
P.S.
The 675 mm radiator used with either the MKI or MKII fan support is cheper than the OEM 575 mm radiator used from the factory install on the MK1 model's
You gain more cooling surface and less money
« Last Edit: December 17, 2010, 05:41:25 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1November 20, 2010, 05:22:23 pm
Re: New Production 191121101Q Upper Radiator Coolant Hose ( Silicone )
« Reply #1 on: November 20, 2010, 05:22:23 pm »
PM sent re: vendor status.   ;)
Reply #2December 17, 2010, 02:11:34 pm
« Reply #2 on: December 17, 2010, 02:11:34 pm »
these are the non ac ones i just received for in my mk1 td
